Stalwart’s Web Push implementation is unusable from any browser. The JMAP logic is
correct — PushSubscription/set, the PushVerification round-trip and StateChange
delivery all work — but the HTTP layer base64-encodes the encrypted payload while
announcing Content-Encoding: aes128gcm, which per RFC 8188 §2 promises the raw
binary octets of the encrypted content coding.
A browser’s push service relays the body verbatim. The user agent then tries to parse
the aes128gcm header block (salt(16) ‖ rs(4) ‖ idlen(1) ‖ keyid) out of what is actually
base64 ASCII text, fails, and drops the message. Chromium reports a decryption failure
and never dispatches the push event; Firefox raises CryptoError in PushCrypto.decrypt
and ACKs with ACK_DECRYPTION_ERROR. In both cases the application sees nothing at all —
not the StateChange, and not even the PushVerification, so a browser client cannot
complete the subscription handshake.
Location (unchanged on main @764c2c1, 2026-07-12):
crates/services/src/state_manager/http.rs:117-118
match ece_encrypt(&keys.p256dh, &keys.auth, body.as_bytes())
.map(|b| base64::engine::general_purpose::URL_SAFE.encode(b)) // <-- here
Ok(body_) => {
body = body_;
client = client.header(CONTENT_ENCODING, "aes128gcm");
crates/services/src/state_manager/ece.rs is fine: the ciphertext it produces decrypts
correctly once the base64 wrapper is removed. The defect is purely the wire encoding.
Why the test suite does not catch it: tests/src/jmap/core/push_subscription.rs:293-296
base64-decodes the body before decrypting —
ece::decrypt(..., &general_purpose::URL_SAFE.decode(body).unwrap())
— so the test passes because of the deviation. A real user agent does not do this.
This most likely explains GitHub issue #3169 (“PushSubscription / EventSource verify
successfully but never deliver StateChange events”), which was auto-closed without
triage. The events are delivered. The browser simply cannot decrypt them.
With Content-Encoding: aes128gcm set, the HTTP body should be the raw octets of the
RFC 8188 / RFC 8291 encrypted content coding, so that a browser can decrypt it and
dispatch the service worker’s push event.
RFC 8188 §2 (“Content-Encoding: aes128gcm”), RFC 8291 §4.
The body is the base64url ASCII text of the ciphertext, sent under the aes128gcm
content-encoding header. No browser can decrypt it, so no push event ever fires and
Web Push is non-functional for every browser-based JMAP client.
Run Stalwart (any 0.16.x; verified on v0.16.11-alpine, and the code is unchanged on
main @764c2c1). -
Stand up an HTTPS endpoint you control that logs the raw request body. Stalwart
requires https:// for a PushSubscription url, and the release build does not accept
invalid certificates (danger_accept_invalid_certs is behind #[cfg(feature =
“test_mode”)]), so use a certificate the server trusts. -
Create a PushSubscription with real RFC 8291 keys. Note that the keys must be PADDED
base64url — Stalwart rejects the unpadded values a browser actually produces; that is
a separate report:{
“using”: [“urn:ietf:params:jmap:core”],
“methodCalls”: [[“PushSubscription/set”, { “create”: { “p”: {
“deviceClientId”: “probe”,
“url”: “https:///push”,
“types”: null,
“keys”: { “p256dh”: “”,
“auth”: “<padded base64url of 16 random bytes>” }
}}}, “a”]]
Capture the POST Stalwart makes to your listener.
Try to decrypt the body as aes128gcm (i.e. exactly what a browser does). It fails.
Base64url-decode the body FIRST, then decrypt: it succeeds.
Not a server-log issue — the server logs PushSubscription(Success). The evidence is on
the wire. Captured POST from Stalwart v0.16.11 to an HTTPS listener:
POST /push (308 bytes)
content-type: application/json
ttl: 86400
content-encoding: aes128gcm
body, first 32 bytes as hex:
306d2d6d4672373333364d3566485531544f73395941414145414242…
the same bytes as text:
“0m-mFr7336M5fHU1TOs9YAAAEABBBGQEMKbzYtwFAxQAtnPO”
decrypting the body as aes128gcm (what a browser does)
→ FAILS: “Public key is not valid for specified curve”
(it is parsing ASCII where the P-256 keyid should be)
base64url-decoding the body FIRST, then decrypting
→ {“@type”:“PushVerification”,“pushSubscriptionId”:“b”,
“verificationCode”:“UbdeWySyZXH1bEyJ9XJZAC0o8pX3nDfD”}
The body is pure base64url ASCII. Everything downstream of the encoding is correct:
after undoing the base64 the payload decrypts cleanly, the verification code round-trips
via PushSubscription/set, and a subsequent StateChange is delivered as expected.
Client: a browser-based JMAP webmail (static SPA, service worker). No proxy, no NAT —
the capture above is a direct POST from the container to a listener on the host.
Suggested fix — send the raw octets instead of a base64 string, i.e. drop the
.map(|b| …encode(b)) and hand reqwest the Vec:
match ece_encrypt(&keys.p256dh, &keys.auth, body.as_bytes()) {
Ok(encrypted) => {
// raw aes128gcm octets, per RFC 8188 §2 — NOT base64
client = client.header(CONTENT_ENCODING, "aes128gcm").body(encrypted);
(That requires letting http_request carry either a String or a Vec body.) The test at
tests/src/jmap/core/push_subscription.rs:293 should then decrypt the body directly,
without the base64 step — which is also what makes the test meaningful.
Note: Content-Type: application/json is retained on the encrypted body. That is what
RFC 8620 §7.2 literally mandates, and push services ignore Content-Type, so it is
harmless. Mentioning it only so it is not mistaken for part of this report.
Two related reports follow separately: (a) PushSubscription/set rejects the unpadded
base64url keys that the W3C Push API produces; (b) RFC 9749 (VAPID) is not implemented,
without which Chromium and Safari cannot receive push at all even once this bug is fixed.
