The individual-principal docs list a picture field — “Stores the account’s profile picture… often used in email clients to display alongside the user’s name or email address.” I’d like to set per-account profile pictures (use case: avatars shown in webmail), but I can’t find where or how in 0.16.x. This is a how-to / docs-clarification question.
What I found
stalwart-cli describe x:Account(server 0.16.6) lists the User fields as:aliases, createdAt, credentials, description, domainId, emailAddress, encryptionAtRest, locale, memberGroupIds, memberTenantId, name, permissions, quotas, roles, timeZone, usedDiskQuota— nopicture.PATCH /api/principal/{id}(the management endpoint shown in the docs) returns 404 on 0.16.x — principal management seems to have moved to thex:Accountschema-object API.- In the source,
pictureonly appears as an OIDC userinfo claim (crates/common/src/auth/oauth/oidc.rs), not as anAccount/principal field.
Questions
- In 0.16.x, is
picturesettable on an individual account? Via which API/field (anx:Accountfield, a management endpoint, or JMAP)? - Where is it stored — the internal store?
- Does it work when the account is backed by an external SQL directory (column mappings are email/secret/class/description/quota — no picture column)? Or is
pictureinternal-directory only? - How do clients retrieve it (JMAP property, HTTP endpoint, OIDC claim)?
Environment
- Stalwart 0.16.6 (also relevant to 0.16.9 per source)
- Install: native binary (GitHub releases)
- Data/blob store: RocksDB
- Directory: external SQL (MariaDB)
Trying to determine whether a native per-mailbox avatar is achievable, or whether the docs are ahead of the 0.16 implementation. Thanks!
