About the Issues category
Bug reports and things not working as expected. Use this category for
reproducible problems against a current Stalwart release; for
“is this expected?” questions, use Questions instead.
Always include:
  • Stalwart version and platform
  • Reproduction steps (minimum sequence of actions that triggers the bug)
  • Expected vs. actual behaviour
  • Trace-level log output around the error (set logging level to trace
    in the Stalwart config if needed)
Confirmed bugs are tracked on GitHub; we will link the issue here.
[!NOTE]
Topics in this category are triaged by the Stalwart Help Bot (an AI assistant) first; a human team member will follow up. If you’d prefer a human-only reply, add the no-ai tag to your topic.
