ACME Provider Lists & Tenancy
A couple of itches regarding ACME Providers.
  1. Low - In the ACME Providers listing pane, you can open up a filter window to find a tenant, but having a column in the main list for Tenant would be great.
  2. Moderate - Currently a separate ACME provider needs to be created for each tenant. Having an option to mark a global use ACME provider would be lovely.
  3. High - When creating a new domain, and you are selecting an ACME provider, the search drop down is just a repeating identical list if you’re using LE for each tenant. No way to distinguish them. You are left to guess and attempt saving until you don’t get the warning about “Item already referenced”. If the tenant attached to that ACME provider could be put in () following the URL, lovely. Bonus if the list can be filtered against the tenant you are working with in the domain - granted not being a programmer I don’t know if that is feasible unless the domain is already created with the tenant flag, unless you can screen scrape the tenant flag chosen.
Point 3 is being addressed in v0.16.17 ACME Providers Are Indistinguishable in Domain TLS Settings - #3 by stalwart but I would still request that a global ACME provider option be created so we can share one with the same properties against multiple tenants.
