Change or remove tenant
Since I ran into problems with the tenant isolation model (I was trying to access the same ACME and DNS backend from multiple domains): can I change the tenant or remove it from all domains without problem or will that break something because of the isolation model?
Here is a direct answer to your two questions:
1. Can you remove the tenant association from domains without breaking things?
Yes. The memberTenantId field on a Domain object is optional (typed as Id<Tenant>?). Clearing it (setting it to null) via the WebUI or JMAP API simply moves that domain back to the global, un-tenanted scope. The domain itself, its DKIM keys, certificates, and DNS settings remain intact.
2. Why ACME/DNS backends don’t work across tenants – and the real fix
The isolation model is the root cause. An AcmeProvider or DnsServer object can itself carry a memberTenantId, which scopes it to that tenant only. Domains in other tenants (or at the global level) cannot reference a tenant-scoped provider.
The clean solutions are:
  • Keep the ACME/DNS provider at the global level (no memberTenantId on the provider object). Per the docs: “A single AcmeProvider can be referenced from any number of Domain records, so one ACME account issues certificates for many domains.” This works regardless of which tenant the domains belong to, as long as the provider itself is not tenant-scoped.
  • Or, remove memberTenantId from all the domain objects so they all sit in the global scope and can freely reference the global provider.
In either case, simply editing the memberTenantId field (to null) on the relevant Domain, AcmeProvider, and/or DnsServer objects in the WebUI is safe and non-destructive to mail flow or certificate state.
Relevant docs:
@helpbot I want to challenge the accuracy of part of your statement bolded below.
  1. Yes, you can assign a non-tenant ACME provider to a non-tenant ID. Your default domain follows this.
  2. Yes, you can assign a tenant scoped ACME provider to a domain under the same scoped tenant.
  3. No, you cannot assign a non-tenant ACME provider to any domain that has tenant scope. That is why both the OP and I have made feature requests for a non-scoped global ACME provider.
Wanted to clarify that for any one else who may read this later and not understand why it doesn’t work.
Edit: There’s a bug present here somewhere, because I was just able to make part of this statement work by not setting the ACME up at the start, but modifying it later, now it’s attached but complaining it has no provider. I will have to investigate further and report an issue.
