Add --secondary flag to stalwart -e so backup can run alongside a live primary
Use case
We’re running Stalwart 0.16.5 with the RocksDB DataStore on a local SSD PVC in Kubernetes. Mail HA + DR is built around being able to back up the DataStore from a sidecar container while the main Stalwart process keeps serving SMTP/IMAP. The intended path is:
# in a CronJob sidecar, same pod as the live Stalwart:
stalwart --config /etc/stalwart/config.json -e /tmp/export-2026-05-13.lz4
This currently fails:
⚠️ Startup failed: Failed to open database:
Error { message: "IO error: While lock file:
  /var/lib/stalwart/data/LOCK: Resource temporarily unavailable" }
The live Stalwart holds an exclusive flock(LOCK) (RocksDB DB::Open() primary mode), so a second process trying to open the same DB as primary blocks. That’s correct RocksDB behaviour — but it means -e is unusable for hot backup of a live instance, which forces operators onto file-level workarounds (restic / tar / borg of the raw data dir) that lose the store-agnostic, app-level-consistent export Stalwart’s -e was designed for.
Proposal
Add a flag — --secondary or --read-only — that opens the DataStore via RocksDB’s DB::OpenAsSecondary() instead of DB::Open():
// rocksdb-rust binding:
DB::open_as_secondary(&opts, primary_path, secondary_path)
RocksDB secondary mode:
  • Does NOT acquire the LOCK on the primary’s data dir
  • Reads SST files + WAL of the primary
  • TryCatchUpWithPrimary() periodically replays the WAL tail into the secondary’s in-memory state
  • Is the upstream-recommended way to do hot reads / backups against a live primary
This is exactly the case -e is missing today.
What would be needed
  1. New flag on the export command (e.g. --secondary).
  2. When set, the DataStore opener picks the secondary path:
    • For RocksDB: OpenAsSecondary(primary_path, secondary_path) where secondary_path is a writable tmpdir for the secondary’s own metadata.
    • For other stores (FoundationDB, PG, etc.): no-op or use the store’s read-only equivalent if any.
  3. After open, optionally call TryCatchUpWithPrimary() so the export reflects state as of the call rather than the (possibly stale) WAL position.
Happy to put up a PR if you’d accept this — wanted to file the design first to check alignment.
Workarounds we’ve considered
  • RocksDB Checkpoint sidecar: call rocksdb::Checkpoint::CreateCheckpoint(\"/tmp/cp\") from a small Rust/C++ tool, then run stalwart -e against an alt-config pointing at /tmp/cp. Works without upstream change, but requires shipping the rocksdb-checkpoint binary in our sidecar image plus maintaining a duplicate config.
  • Stop Stalwart briefly: not viable for mail (breaks SMTP/IMAP).
  • File-level restic backup of the raw data dir: what we run today — works but loses app-level consistency (relies on RocksDB WAL replay on restore) and isn’t store-agnostic (tied to the on-disk RocksDB format, breaks if we ever switch DataStore).
Native -e --secondary would be much cleaner than any of these.
Thanks for considering!
