Does the admin panel support OIDC?
Thanks for help.
Yes, the Stalwart admin panel (WebUI) does support OIDC for authentication. The WebUI uses the standard OAuth 2.0 authorization code flow and will automatically detect OIDC support from the server’s discovery document — requesting openid, email, and profile scopes when the identity provider advertises them.
This means if your Stalwart server is configured to use an external OIDC directory backend (e.g. Keycloak, Authentik, or any generic OIDC provider), the admin panel login will follow that same OIDC flow via the server’s built-in OAuth 2.0 support.
For details on setting up an OIDC directory backend, see the OpenID Connect docs.
@helpbot Will app passwords fail to work in this case?
It depends on whether you’re using an external OIDC directory or the internal directory. The docs are explicit about this:
“Application passwords are stored against the internal directory’s account record. When the principal originates in an external directory (LDAP, SQL, OIDC), the secret has to live in the external directory, not in Stalwart. For clients that do not speak SASL OAUTHBEARER (CalDAV / CardDAV in particular), either configure the external directory to accept the application password as a secondary credential, or run a hybrid setup with the internal directory covering app-password use.”
— FAQ
In short:
The OIDC backend docs and OAuth interoperability page cover the workaround in more detail.
Human here! Helpbot’s reply is correct but the quoted FAQ is referencing old behaviour from v0.15. The correct answer is that yes, in v0.16 you can use App Passwords with any external directory. The FAQ has been updated to correct that.
External OIDC only works if you can set the client id “stalwart-webui” in your IDP. If your IDP generates the client id itself, you’ll have to patch webui.
I checked your post on GitHub, thanks for the help.
I’d like to see this configurable, or at least more documented.
Thanks, I can configure my IdP provider (Kanidm) to use stalwart-webui client id, but I don’t like the fact that my Roundcube webmail must use this client as well. I’d like to use client with more generic name (email) or two separate clients for Stalwart and Roundcube.
Agree it would be great to document the required audience / client ID requirement. What confused me further was that the documentation suggests the value “stalwart” which is directly incompatible with the web UI for IDPs like Kanidm which propagate the client ID to aud.
Based on the README of GitHub - stalwartlabs/webui: Stalwart WebUI · GitHub it looks like there’s an env var VITE_OAUTH_CLIENT_ID to override this, though? This would also be great to document if true.
