Allow plain authentication for IMAP
How do I allow for a listener with IMAP protocol AND without TLS plain authentication?
I know the security implications and it’s NOT over a public network.
I’m using Stalwart v0.16.
I have the answer now.
To allow IMAP clients to authenticate with plain credentials over an unencrypted connection, enable the allowPlainTextAuth field on the Imap settings object (Settings › Network › IMAP in the WebUI). It defaults to false.
Via the WebUI, go to Settings → Network → IMAP and toggle “Allow plain text authentication” on.
Via stalwart-cli:
stalwart-cli update Imap --field allowPlainTextAuth=true
Or via the JMAP API with an x:Imap/set call updating the singleton record’s allowPlainTextAuth field to true.
This setting is separate from TLS configuration on the network listener itself: it only controls whether the IMAP protocol layer accepts cleartext credentials, not whether the listener has TLS enabled at all. Since you’ve noted this is on a trusted network, enabling it is sufficient without any listener-level TLS changes.
Reference: Imap | Stalwart
