Securing the web interface
I’m setting up stalwart, and I’d like to further lock down the public web interface. As far as I can find /api shouldn’t really be exposed publicly, the rest seems fine (going by Overview | Stalwart )
I setup a separate admin-http listener bound to 127.0.0.1, and put a reverse proxy in front of it (so I still can have TLS enabled) which listens on port 8443, but I’m having a hard time restricting the flow to the public endpoint (443)
Trying to implement basically
  "allowedEndpoints": {
    "match": [
      {"if": "listener == 'admin-http' || contains(['jmap', 'robots.txt', '.well-known'], split(url_path, '/')[1])", "then": "200"}
    "else": "404"
stalwart-cli get Http --url https://public-url  --api-key API_redacted
Response
  Headers:       <none>
  Redirect root: /account
Proxy
  Obtain remote IP from Forwarded header: Yes
Security
  Allowed endpoints:
    Expression
      Conditions:
        #  Condition        Result
        0  "listener == 'admin-http' || contains(['jmap', 'robots.txt', '.well-known'], split(url_path, '/')[1])"  200
      Default Value: 404
  Enable HTTP Strict Transport Security: No
  Permissive CORS policy:                No
Rate Limit
  Authenticated:
    Rate
      Count:  1000
      Period: 1 m
  Anonymous:
    Rate
      Count:  100
      Period: 1 m
Listeners:
Id            Name         Protocol     Bind addresses  Implicit TLS
i7qcfx0uabaa  admin-http   HTTP         127.0.0.1:8080  No
i7lyonbeahab  https        HTTP         [::]:443        Yes
i7lyonbeagqb  sieve        ManageSieve  [::]:4190       No
i7lyonbeafqb  imaps        IMAP4        [::]:993        Yes
i7lyonbeafab  submissions  SMTP         [::]:465        Yes
i7lyonbeaeqb  smtp         SMTP         [::]:25         No
doing simple tests like
curl https://<public hostname/api/schema
and
curl https://<internal hostname>:8443/api/schema
both keep returning 401, where i’d expect the public to return 404
Well, putting the telemetry to TRACE helped me
The correct syntax is
listener == 'admin-http' || contains(['jmap', 'robots.txt', '.well-known'], split(url, '/')[1])
so url instead of url_path, drop the quotes.
The documentation needs to be updated - Access Control | Stalwart mentions url_path.
I am trying to do a similar thing and have HTTP(S) listeners only on a private network. I had it working in the past with the config.toml, but with the newest version of Stalwart setting to a specific IP in the GUI is disabled and they have moved config.toml setting into the DB.
Do you have a workaround that works with the current versions config workflow?
