Ways it works:
Create the contacts on the apple devices and ONLY edit on the apple devices = everything okay.
HOWEVER
If you then update the avatars using Android with Google Contacts and sync them with dav5x, contacts will no longer update on ANY apple device. I have verified this on the iPhone, iPad, and Mac.
Yet, the contacts DO sync with the server itself. Because roundcube can correctly see the new avatars :S
