Here is a consolidated set of best practices for running Stalwart behind an inbound AV/spam filtering relay (the “Sender → AV relay → Stalwart → Recipient” topology):
1. Preserve the real client IP via Proxy Protocol
The AV relay is just another SMTP proxy. Without knowing the original sender’s IP, Stalwart’s SPF/DMARC checks, rate-limiting, and auto-banning all run against the relay’s IP, which is useless (and will self-ban your relay).
- Configure the relay to emit Proxy Protocol headers on its connections to Stalwart.
- On Stalwart’s listener, enable Proxy Protocol acceptance and mark the relay’s IP as a trusted network.
Docs: Reverse proxy overview - Preserving the client IP and Proxy Protocol
2. Use a dedicated listener for the relay
Create a separate SMTP listener (e.g. on a private interface or non-standard port) exclusively for your AV relay. This lets you write targeted expressions for just that listener, e.g.:
{"name": "relay-in", "protocol": "smtp", "bind": ["127.0.0.1:10025"]}
Docs: Listeners
3. Disable Stalwart’s built-in spam filter for the relay listener
Since the AV relay has already scanned the message, you don’t want Stalwart to re-scan it. The enableSpamFilter field in the DATA stage accepts an expression - scope it to skip your relay listener:
"enableSpamFilter": {
"match": [{"if": "listener == 'relay-in'", "then": "false"}],
"else": "is_empty(authenticated_as)"
Docs: Inbound DATA - Spam filtering
4. Relax or bypass SPF/DKIM/DMARC checks for the relay
SPF will legitimately fail when the relay re-sends mail, since its IP is not in the sender’s SPF record. Use the remote_ip or listener variables in the SenderAuth expressions (spfVerify, dkimVerify, dmarcVerify) to set them to disable or relaxed for connections from the relay.
Docs: DMARC Verification, SenderAuth object
5. Restrict the relay-in listener to the relay’s IP only
Use the isClientAllowed / connection-stage expression or firewall rules to ensure only your relay can connect to this listener - preventing it from becoming an open relay. If you want Stalwart to accept relayed mail (to local recipients) from the relay without authentication, adjust allowRelaying scoped to that listener’s IP:
"allowRelaying": {
"match": [{"if": "listener == 'relay-in' && remote_ip == '10.0.0.1'", "then": "true"}],
"else": "!is_empty(authenticated_as)"
Docs: Inbound RCPT - Relay
6. (Optional) Trust X-Spam headers from the relay
If your AV relay adds X-Spam-Status or similar headers, you can write a Sieve rule or MTA Hook to consume those and act on them instead of running Stalwart’s own filter.
Docs: MTA Hooks, Sieve scripting
In summary: create a dedicated listener for the relay, enable Proxy Protocol so the real sender IP flows through, scope spam/auth checks to skip that listener, and lock down allowRelaying to the relay’s IP only.
