I was trying stalwart 0.16.4, and when booting and doing the setup I receive a 500 error, I’m trying to configure it with SQLite and everything stored in it.
I could boot another testing instance and worked fine, the only difference I see in this environment is that I do have the port 80 and 443 used by an http server which is actually going to proxy stalwart http access.
Another point in the new setup I do not see options to enable/disable/configure any of the listeners or services, this is probably going to create issues with the existing http server.
You could always try stopping your proxy server and run the setup again to confirm? You edit the listener bindings in bootstrap mode. Connect to http://<hostname>:8080/admin and go into Settings > Network > Listeners. You can change IP and port bindings there.
Yes I was thinking to do that, but I need to do some fancy tunnel for avoid to do a setup on clear net, anyway I do not see any menu from admin mode, I didn’t manage to arrive at the level that I see any menu, I’m still in bootstrap.
Is there any way I can see the enable additional logging? like a “RUST_LOG” env variable ? (spoiler, tried that and it don’t works)
OpenTelemetry is an open-source standard for distributed tracing and metrics. It defines a common set of APIs, SDKs, and collector services that applications use to emit traces, logs, and metrics to an observability backend.
Sure I can read that from the homepage of opentelemetry
OpenTelemetry is an open source observability framework for cloud native software. It provides a single set of APIs, libraries, agents, and collector services to capture distributed traces and metrics from your application.
But still I do not know how to enable the logs if I do not have a UI working …
I’m going to hack in the code soon, but I’m giving the docs and this forum a chance
So I figured out some of the issues, when I was configuring the sqlite storage I was putting there the path of the parent folder instead of the path of the file, I figure this out removing the proxy, when I did that the error showed up in the right place, not sure what was messing with it, I do need to investigate more.
So for anyone coming by be aware of the path of the sqlite config need to be a file.
Will update when I do get more details on where the real error got lost.
