Bug: DSN bounces are emitted with a malformed Message-ID (doubled angle brackets)
Delivery Status Notifications are generated with doubled angle brackets around the Message-ID:
Message-ID: <<18cad7807852b60b.f790fe4fd1ab9090.76e3c80726c2224c@mail.example.org>>
RFC 5322 defines msg-id = "<" id-left "@" id-right ">" with id-left = dot-atom-text; < is not valid atext, so this header is malformed. Consumers that key on Message-ID — threading, duplicate suppression, loop detection, log correlation — may fail to match it, and strict parsers reject it.
The message being bounced had a well-formed, single-bracketed Message-ID, so the doubling is introduced by the DSN generator rather than inherited from the original.
Probable cause: crates/smtp/src/queue/dsn.rs:339 wraps the id in angle brackets before handing it to the builder:
.message_id(format!("<{}@{}>", make_boundary("."), reporting_mta))
mail-builder then adds its own, unconditionally, in src/headers/message_id.rs:106:
output.write_all(b"<")?;
output.write_all(id.as_bytes())?;
output.write_all(b">")?;
MessageId takes the bare id and owns the delimiters, so the caller should not supply them. Dropping the brackets at the call site looks like it would fix it:
.message_id(format!("{}@{}", make_boundary("."), reporting_mta))
crates/http/src/form/mod.rs:160 pre-wraps in the same way before calling .message_id(). I have not observed that path in the wild, but it goes through the same builder.
For contrast, crates/imap/src/op/fetch.rs:881 also wraps in angle brackets, but that value is not passed to mail-builder, so it looks correct as written.
The DSN carries a single-bracketed, RFC 5322 conformant header:
Message-ID: <18cad7807852b60b.f790fe4fd1ab9090.76e3c80726c2224c@mail.example.org>
The header is emitted with doubled brackets, as shown above.
Both the Message-ID and the MIME boundary in the same DSN come from make_boundary, whose first field derives from SystemTime::now().as_nanos(). In the bounce I received they share a nanosecond-level prefix, which is what convinced me the header was generated by this code path rather than altered in transit:
Message-ID:  18cad7807852b60b.f790fe4fd1ab9090.76e3c80726c2224c
boundary:    18cad7807860371a_2cb9a36d49c2f6d7_88535f8daf886636
  1. Send a message to an address that will hard-fail, so a DSN is generated.
  2. Inspect the raw source of the resulting bounce.
The Message-ID header shows doubled angle brackets.
This confirms the exact code the user cited. This is a legitimate source-level bug report, not really a “how do I use this” question — the correct action is to acknowledge it clearly and accurately since I’ve verified it in the current source.
This matches what’s in the source. In crates/smtp/src/queue/dsn.rs, the DSN builder does indeed call:
and since mail-builder’s message_id() helper already wraps the value in angle brackets when writing the header, pre-wrapping the value here as you describe would produce the doubled <<...>> you’re seeing. Your proposed fix (passing the bare id@domain without brackets) lines up with how mail-builder expects MessageId values to be supplied.
This is a legitimate bug report grounded in the actual source, not something covered by existing documentation, so I won’t try to adjudicate further here. A human maintainer will need to confirm and land the fix.
