Cache.messages defaults to 50 MiB, but Cache::new() constructs quick_cache::sync::Cache without specifying a shard count. quick-cache therefore defaults to four shards per detected CPU, with independent capacity per shard.
A MessageStoreCache larger than one shard’s hot allocation is evicted during PlaceholderGuard::insert(). quick-cache returns Ok(()) for this case, so Stalwart treats the insertion as successful. The next access misses and runs another full_cache_build().
MessageStoreCache constructions
A MessageStoreCache smaller than the configured total Cache.messages size should remain cacheable, or Stalwart should detect and report failed admission.
Entries too large for the cache are silently discarded and then constantly re-inserted causing extremely high database load
Here’s a test:
#[cfg(test)]
mod tests {
use super::*;
#[derive(Clone, Debug)]
struct WeightedValue(u64);
impl CacheItemWeight for WeightedValue {
fn weight(&self) -> u64 {
self.0
#[tokio::test]
async fn placeholder_insert_retains_value_smaller_than_total_capacity() {
let cache =
Cache::<u32, WeightedValue>::new_estimated(1024, 50 * 1024 * 1024);
assert!(cache.inner().num_shards() > 1);
let value = WeightedValue(cache.inner().shard_capacity());
assert!(value.weight() < cache.inner().capacity());
let guard = cache
.get_value_or_guard_async(&1)
.await
.expect_err("cache should initially miss");
assert!(guard.insert(value).is_ok());
assert!(
cache.get(&1).is_some(),
"insert returned Ok but the value was not retained"
OIDC
