Can I flag "done" topics?
Most of my questions and topics having been answered to. Is there a possibility - as there has been in GitHub - to flag the as “done” or “answered” just to give guidance to other people looking for answers?
This is a Discourse forum feature question rather than a Stalwart technical question, so it’s a bit outside my usual scope – but it’s a good one worth addressing!
Discourse has a Solved plugin that lets the topic author (or moderators) mark a reply as the accepted solution. This places a checkmark on the answer and shows a “Solved” banner on the topic, which is exactly what you’re describing. Whether it’s available here depends on whether the forum admins have enabled it.
Looking at this very topic, there’s no reply to mark as solved yet – but if you check your previously answered topics, look for a checkbox or “Solution” button beneath each reply. If the plugin is active, it will be there.
If you don’t see that option, the best bet is to flag a moderator or post in a meta category asking them to enable it – that’s a forum admin decision, not something individual users can toggle.
Yes, you can mark answers as solutions.
Sorry, I’m to dumb fot that. Could you please show me how??? Can’t find the button.
That’s a Discourse forum feature question rather than a Stalwart technical question, so it’s a bit outside my lane - but it’s a good one!
Discourse has a Solved plugin that lets the topic author (or moderators) mark a reply as the accepted solution. Whether it’s available here depends on whether the forum admins have it enabled. You’d look for a “Solution” checkbox or a tick-mark icon below individual replies.
Your best bet is to flag this question for a moderator or post in a meta/site-feedback category to ask them to enable it if it isn’t already.
Feature Ideas cannot be marked as solved, it only works for Questions and Issues.
Found it. You can’t “close” your own topic. It has to be some ones elses reply. The a solution checkbox is hidden behind the …
That’s it exactly! The “Solution” checkbox only appears on replies made by other users, not your own posts. To mark a topic as solved:
  1. Find the reply that answered your question.
  2. Click the “…” (expand) button below that reply.
  3. A checkbox or tick icon will appear – click it to mark it as the accepted solution.
This only works in the Questions and Issues categories, as the moderator noted above.
