Configurable IMAP Greeting
Add a configurable imapGreeting field to the Imap singleton, similar to the existing smtpGreeting in MtaStageConnect.
Problem Statement
Currently, the IMAP greeting is hardcoded as:
* OK Stalwart IMAP4rev2 at your service
This lack of configurability poses a privacy and security concern, as administrators cannot customize or obfuscate the server identity in the IMAP banner.
Proposed Solution
  • Introduce a imapGreeting field in the Imap singleton.
  • Allow administrators to define a custom IMAP greeting string via configuration.
  • Default to the current hardcoded greeting if no custom value is provided (to preserve backward compatibility).
Benefits
  • Enhances privacy/security by allowing admins to mask server identity.
  • Provides consistency with SMTP, where smtpGreeting is already configurable.
  • Improves flexibility for deployments in sensitive environments.
