Database migration fails in v0.16.7 with subspace_g being not empty
TL;DR: When trying to move between RocksDB and PostgreSQL the import fails on importing subspace_g as the table is not empty. Clearing the table does not work as the sole key in there is automatically re-created.
Please see a full reproduction, reason and description of the issue posted by another person (and then auto-closed by a bot) in this issue: --import aborts on its own store-identity marker, making backend migration impossible (0.16.15+) · Issue #3273 · stalwartlabs/stalwart · GitHub
Confirming this bug — reproduced independently, v0.16.18
We hit this exact issue during a Postgres-backed migration (RocksDB source → PostgreSQL target, --export/–import). Full details:
  • subspace_g (SUBSPACE_REGISTRY_PK) consistently exports truncated. We reproduced this 3 separate times from the same (stopped) source instance: a trial export, a full export, and a
    fresh EXPORT_TYPES=registry-only export — all three produced a subspace_g file around ~74KB, ending mid-record.
  • Cross-checked against a direct ldb --column_family=g --hex scan dump of the live RocksDB: the correct record count is 5193; the exported file only parses cleanly to ~4773 records
    before hitting a truncated final entry (confirmed via LEB128-boundary parsing, not just file size).
  • subspace_i, subspace_s, and other subspaces exported and imported correctly from the same source — this appears isolated to g specifically, likely size- or content-dependent (e.g.,
    encoder buffer not fully flushed/closed for larger payloads).
  • Consequence downstream: since g holds the RegistryClass::PrimaryKey/Reference entries, an import missing this data results in domain/account objects existing (import of s succeeds
    fine) but all inbound SMTP RCPT TO resolution failing with 550 5.1.2 Relay not allowed for every domain — the domain(name) lookup misses entirely, even on a fresh cache. This is a
    silent, hard-to-diagnose failure: the admin UI and CLI queries (which apparently read via a different path) show all data present and correct, while live mail delivery is completely
    broken until g is manually rebuilt.
  • Workaround: bypass --export/–import for g entirely — extract directly from the live RocksDB via ldb --column_family=g --hex scan, and load into the target via COPY … FORMAT csv (not
    FORMAT text — Postgres’s text-format backslash-escaping conflicts with the \x-prefixed hex bytea representation and corrupts the data with embedded NUL bytes).
Happy to share more detail (schema version, exact repro steps) if useful for tracking this down.
