I got a report that suddenly old mail shows up on the inbox. The same I can confirm on GMail on mobile and Thunderbird on computer for my own mail. In Thunderbird I can sort and it resorts properly, but that is a manual override. And it does not change display in Gmail App. So it seems the database index is sorting correctly. Happened after we moved a large mail account but obviously not just on that large mail account.
Log is on trace, but does not show anything in the UI
I have not even an idea how to debug this, any help much appreciated!
Display eMail in descending date order by default.
Inbox corrupted, showing two newer mails then mails from 2025.
In Thunderbird mails still show, in GMail mails between last mail and 2025 went amiss.
Open Mail Client.
Where can I recreate the mail index?
What logs would be relevant. I cannot see any. But as that happens on multiple mail clients, the cause is very likely on the server side?
Don’t know what is “relevant”?
Jun 03 01:43:29 mindship-syl stalwart[2614]: Write batch operation
Jun 03 01:43:29 mindship-syl stalwart[2614]: Data store iteration operation
Jun 03 01:43:48 mindship-syl stalwart[2614]: IMAP connection started
Jun 03 01:43:48 mindship-syl stalwart[2614]: Raw IMAP input received
Jun 03 01:43:48 mindship-syl stalwart[2614]: Cache hit
Jun 03 01:43:48 mindship-syl stalwart[2614]: Cache miss
Jun 03 01:43:48 mindship-syl stalwart[2614]: Data store iteration operation
Jun 03 01:43:48 mindship-syl stalwart[2614]: Authentication successful
Jun 03 01:43:48 mindship-syl stalwart[2614]: Raw IMAP output sent
Jun 03 01:43:48 mindship-syl stalwart[2614]: IMAP ID command
Jun 03 01:43:48 mindship-syl stalwart[2614]: IMAP SELECT command
Jun 03 01:43:48 mindship-syl stalwart[2614]: IMAP LIST command
Jun 03 01:43:48 mindship-syl stalwart[2614]: IMAP SEARCH command
Built from source
Gmail Version 2026.05.11
Thunderbird 140.11
Stalwart 0.16.5
stalwart-cli 1.0.6
