So I have first setup my stalwart account on my iPhone using outlook and the account password. Then I setup an app-password and setup the mailbox in thunderbird desktop using the app password. On iOS I can see the assigned groups as shared mailboxes. However on thunderbird I can not.
Group mailboxes should show up
Group mailboxes not showing
- Setup app-password
- Logged in using app-password
This is expected client-side behavior related to IMAP folder subscriptions, not a Stalwart bug. Group inboxes appear as shared IMAP folders, but shared/other-user folders are not automatically subscribed by default in most IMAP clients, and Thunderbird only displays subscribed folders unless you tell it otherwise.
To fix it in Thunderbird:
- Right-click the account (not a folder) → Manage folder subscriptions (or Subscribe).
- Look under the “Shared” / “Other Users” namespace for the group’s mailbox and check the box to subscribe to it.
- If you don’t see the “Manage folder subscriptions” option, make sure “Show only subscribed folders” is toggled appropriately in Account Settings → Server Settings → Advanced.
iOS Mail may auto-subscribe or show all folders regardless of subscription state, which is why it appears there but not in Thunderbird until you manually subscribe. This is a Thunderbird/IMAP client subscription behavior, not something configured on the Stalwart server side, since the docs only note that group inboxes appear “as a shared folder in their email client when using IMAP or JMAP” without controlling per-client subscription state.
Reference: Group | Stalwart and IMAP and POP3 | Stalwart
