I’m trying to run the Stalwart bootstrap using PostgreSQL, however whenever I attempt to do so, I get a very generic error message that does not really give me any information about what specifically is going wrong:
Failed to initialize data store: PostgreSQL error (store.postgresql-error): reason = Error occurred while creating a new object: db error
I’m able to connect to the database from the same server using the same connection details and I’m able to create tables, etc. However the database is otherwise empty because Stalwart’s bootstrap never appears to actually be able to get to that point.
I cannot find any knob to tweak to get more information out of Stalwart about what exactly is failing.
If it helps at all, this is running on a Digital Ocean Droplet with their managed PostgreSQL database.
I would either get a helpful error message that would point to what the issue is, or it would create the needed tables.
The bootstrap gives the error
- Setup a DO Droplet and PostgreSQL Instance
- Attempt to bootstrap Stalwart using the above.
I don’t know how to get more logging out of Stalwart before bootstrapping.
