Migration from postgres to foundationdb in 0.16
After migrating from a postgres data store to a foundationdb data store I’m getting some errors.
No errors or warnings when starting Stalwart after the migration is done.
I’m getting the following error messages when starting stalwart.
stalwart-node-2 | 2026-07-24T14:03:54Z ERROR Configuration build error (registry.build-error) source = “HttpLookup”, id = 320067344640765952, reason = “An lookup store with the stwt_openphish namespace already exists”
stalwart-node-2 | 2026-07-24T14:03:54Z ERROR Configuration build error (registry.build-error) source = “HttpLookup”, id = 320067344808538624, reason = “An lookup store with the stwt_phishtank namespace already exists”
stalwart-node-2 | 2026-07-24T14:03:54Z ERROR Configuration build error (registry.build-error) source = “HttpLookup”, id = 320067344974214144, reason = “An lookup store with the stwt_disposable_domains namespace already exists”
stalwart-node-2 | 2026-07-24T14:03:54Z ERROR Configuration build error (registry.build-error) source = “HttpLookup”, id = 320067345144083968, reason = “An lookup store with the stwt_free_domains namespace already exists”
  1. Use the stalwart --config /etc/stalwart/config.json --export command to make a dump of the postgres datastore
  1. Reconfigure (in config.json) to use foundationdb a data store
  2. Use the stalwart --config /etc/stalwart/config.json --import command to import the data into foundationdb
  3. Start stalwart
FoundationDB
Fixed in v0.16.15 (yet to be released). The fix consists of aborting an import if the store already contains data.
