On first start Stalwart creates an MtaQueueQuota “Global queue quota” with enable=true, 100000 messages and 10737418240 bytes, but with an empty match expression. Quotas with an empty expression are skipped, so neither limit is enforced.
x:MtaQueueQuota/get returns for this object:
{“enable”: true, “description”: “Global queue quota”, “key”: {}, “match”: {“match”: {}, “else”: “”}, “messages”: 100000, “size”: 10737418240}
Code (v0.16.24):
- crates/common/src/manager/defaults.rs L101-113: the quota is created with the match expression left at its default (empty).
- crates/common/src/expr/if_block.rs L97: an expression with an empty “else” and no “match” entries compiles to an empty IfBlock.
- crates/smtp/src/queue/quota.rs L130-177: limits are checked and quota accounting is recorded only when !quota.expr.is_empty() && eval_if(…). With an empty expression the function returns true without checking or recording anything.
Inbound and outbound throttles treat an empty expression the opposite way: they apply when the expression is empty or true (crates/smtp/src/core/throttle.rs L182, crates/smtp/src/queue/throttle.rs L30).
The documentation’s global quota example uses the same limits with “match”: {“else”: “true”}: Quotas | Stalwart
The enabled global queue quota created at setup enforces its message and size limits.
The quota is shown as enabled with its limits, but check_quota() skips it, so the queue has no global limit.
- Start a new Stalwart v0.16.24 installation.
- Read the “Global queue quota” with x:MtaQueueQuota/get: enable is true, the limits are set, and match is {“match”: {}, “else”: “”}.
- Follow the expression through compile_expr() and check_quota(): the empty IfBlock bypasses both limits.
The quota is created only when no MtaQueueQuota object exists (defaults.rs L101), so installations that already hold it keep the empty expression unless existing objects are also covered.
