Destination host for: API Key (for auto-renewal)
I noticed my Stalw.art enterprise does not renew, and I suspect the API key license destination isn’t allowed via the firewall.
What is the exact hostname and URL the Stalw.art enterprise use for the license updates?
The license-renewal API endpoint the server calls is https://license.stalw.art/api/license/, served over HTTPS (port 443) at host license.stalw.art. That’s the only destination the automatic renewal feature needs to reach: if your firewall blocks outbound HTTPS to license.stalw.art, renewal will silently fail and the license will expire.
For reference, this is the same host used for the Licensing Portal where you generate the API key, documented at Enterprise licensing.
