I am carefully following Docker | Stalwart to install Stalwart on a freshly-provisioned Debian 13 VM [1]. Setup goes smoothly, with me choosing the default options in the wizard of everything except
- host/domain name (page 1)
- My choosing automatic DNS management via Porkbun. I believe that Porkbun is set up correctly, with an API key and with API access enabled for the domain in question
However, when the instructions request me to visit https://my-hostname/admin I receive an error page in Firefox with the complaint that
mailbox.12rocks.io uses an invalid security certificate.
The certificate is not trusted because it is self-signed.
Error code: MOZILLA_PKIX_ERROR_SELF_SIGNED_CERT
View Certificate
I know that stalwart is up: I can access http://my-hostname:8080/admin/ just fine. However logs are completely uninformative, with docker logs stalwart only reporting logs until the restart I issued as part of the guide (side note: where the hell are the logs???)
mailbox# docker logs stalwart
🔑 Stalwart bootstrap mode - temporary administrator account
username: admin
password: [REDACTED]
Use these credentials to complete the initial setup at the
/admin web UI. Once setup is done, Stalwart will provision a
permanent administrator and this temporary account will no
longer apply.
This password is shown only once. To pin a credential
instead, set STALWART_RECOVERY_ADMIN=admin:<password> in the
env file.
2026-06-01T04:02:17Z WARN Server started in bootstrap mode (server.bootstrap-mode) hostname = "e264acdf3a86", details = "No configuration file was found. Port 8080 is open for initial setup.", version = "0.16.7"
2026-06-01T04:02:18Z INFO Application resource updated (resource.application-updated) url = "https://github.com/stalwartlabs/webui/releases/latest/download/webui.zip", details = "Stalwart Web Interface"
2026-06-01T04:02:18Z INFO Network listener started (network.listen-start) listenerId = "http-recovery", localIp = ::, localPort = 8080, tls = false
2026-06-01T04:08:30Z ERROR Authentication error (auth.error) listenerId = "http-recovery", localPort = 8080, remoteIp = 172.17.0.1, remotePort = 38976, details = "Failed to decode token. If you are using an external OIDC provider, make sure it is configured as the default directory under the Authentication object.", causedBy = "crates/common/src/auth/oauth/token.rs:210", reason = "aead::Error", causedBy = "crates/http/src/auth/oauth/token.rs:235", details = "Failed to validate refresh token"
2026-06-01T04:08:36Z INFO Authentication successful (auth.success) listenerId = "http-recovery", localPort = 8080, remoteIp = 172.17.0.1, remotePort = 38976, accountName = "admin"
2026-06-01T04:14:03Z INFO Shutting down Stalwart Server (server.shutdown) causedBy = "SIGTERM"
Obviously TLS is broken: at a total guess, I suspect that it might have something to do with Porkbun integration being broken: I don’t see any records created for the relevant domain
I should be able to navigate to https://my-domain/admin without error like the guide instructs
As mentioned earlier, docker logs stalwart is useless. From inside the container, nothing in /var/lib/stalwart/LOG appears to be interesting either (though it’s quite noisy so who knows?)
