Email Aliases don't work
On the latest stalwart I moved a user between two different email/stalwart servers.
This user (me) had several masked email addresses.
I re-created the masked emails as aliases on the new server, and no email is arriving to them.
I can confirm emailing the user regularly works fine.
Aliases should work
They don’t work
Create an alias such as:
xzfxjvhdz9g6vzzd.9b7xicgxhb6hsd93rgf3czey
And it doesn’t work
N/A
Let me look into how aliases work in Stalwart to help diagnose this.
There are two important things happening here that likely explain why the aliases aren’t working.
The core issue is almost certainly that masked email addresses are an Enterprise Edition feature, not standard aliases.
The address format you described (xzfxjvhdz9g6vzzd.9b7xicgxhb6hsd93rgf3czey) matches the auto-generated format of Stalwart’s Masked Email feature - not a regular account alias. These are distinct objects in Stalwart:
  • Regular aliases are simple email address entries linked to an account (e.g. [email protected]).
  • Masked emails are disposable addresses managed as MaskedEmail objects via the JMAP API. They must be created through Stalwart’s masked email system (WebUI Account Manager, CLI, or JMAP API), not simply added as an alias string on an account.
Key points:
  1. Masked email is an Enterprise Edition feature only. If your new server does not have an Enterprise license, these addresses cannot be routed at all, even if you manually create aliases with those names.
  2. Even with an Enterprise license, you cannot simply re-create a masked address as a plain alias. You need to recreate the masked email records as proper MaskedEmail objects (via WebUI under Account > Masked Addresses, the CLI with stalwart-cli create masked-email, or the JMAP API). The server resolves them differently from regular aliases.
  3. The emailPrefix field (the generated local part) only accepts characters a-z, 0-9, and _ (underscore) - and notably dots (.) are not permitted in the prefix. If the original addresses contained dots in the local part, that could also be a complication to be aware of.
What to do:
  • If you have an Enterprise license, recreate the addresses as proper MaskedEmail objects via the WebUI (Account > Masked Addresses) rather than as plain aliases.
  • If you don’t have an Enterprise license, masked email routing is not available and you would need to use regular aliases with different (non-masked) addresses instead.
See the docs for full details: Masked email | Stalwart
Thanks but:
A) This is an enterprise server
B) Even if it wasn’t, it’s still an alias and should work (it is not a masked address anymore).
Also since this is a fresh/new installation that never had the masked addresses on it originally, it should be possible to create them as an alias.
I setup a catch all email and removed (one) of the aliases and I’m not seeing that email hit my catch all account.
This is very interesting..
I think I see what’s happening, and it’s specific to Enterprise. Recipient resolution runs the masked-email decoder before it checks normal aliases, and a local part shaped like prefix. with a matching checksum gets treated as a masked address. When that decodes but there’s no live masked-email object behind it (which is the case for an alias you created by hand, or strings carried over from another server), resolution returns “mailbox does not exist” right there and never looks at your alias, and also skips catch-all, which is why setting a catch-all didn’t help either.
So an alias whose local part happens to match the masked-address format is effectively unusable as a plain alias today. Quick check to confirm: is the failing local part exactly that single-dot prefix.base36 shape, and was it ever an actual masked email or just a string you chose? If you can use an alias local part that doesn’t match that pattern (anything that breaks the base36 second segment), it’ll deliver normally.
I’m trying to setup an alias of a masked email that existed on a previous server but never existed on this new server.
Both servers are enterprise.
Also catch all account isn’t receiving email either for this address.
I’m hoping there is a fix as I need access to this email address even if its just from the admin catch all account.
If not I’ll live and deal I guess.
This should be fixed in v0.16.12 which will be released this week.
