Group membership and account (read/write) delegation
Is that possible via the current WebUI?
Or only vis CLI tooling?
Let me look up how group membership and account delegation are managed in Stalwart.
Both group membership and account delegation are fully manageable through the WebUI’s administrator console – no CLI required.
Group membership: In the admin console, go to Management > Directory > Groups to create/edit groups and add or remove members. You can also edit an individual account (Management > Directory > Accounts) and set its memberOf field to place it into groups.
Read/write delegation (shared inbox): Adding a user as a member of a group gives them access to that group’s inbox as a shared folder in their email client. For full account impersonation (read/write access to another user’s mailbox), you grant the impersonate permission to an account via a Role – also done through the WebUI at Management > Roles. Once that permission is assigned, the delegating account signs in with a composite login of the form [email protected]%[email protected] using the delegator’s password.
All of these operations are available directly in the WebUI; the CLI (stalwart-cli) can do the same things but is not required.
Relevant docs:
