Hello,
I have this apache2 vhost config.
it works, but i have the impression it is not using autoconfig etc.
how should an optimal vhost config look like?
<VirtualHost *:80>
ServerName mail.example.de
ServerAlias mail… mail…de … some more
Redirect permanent / https://mail…de/
<VirtualHost *:443>
ServerName mail…de
ServerAlias mail…
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/mail.....de/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/mail.....de/privkey.pem
ProxyAddHeaders On
ProxyPreserveHost On
ProxyRequests Off
ProxyPass /jmap/session http://127.0.0.1:8080/jmap/session
ProxyPassReverse /jmap/session http://127.0.0.1:8080/jmap/session
ProxyPass /.well-known/jmap http://127.0.0.1:8080/jmap/session
ProxyPassReverse /.well-known/jmap http://127.0.0.1:8080/jmap/session
ProxyPass / http://127.0.0.1:8080/
ProxyPassReverse / http://127.0.0.1:8080/
ErrorLog ${APACHE_LOG_DIR}/stalwart-error.log
CustomLog ${APACHE_LOG_DIR}/stalwart-access.log combined
Autoconfig and autodiscover rely on DNS more than on any special Apache proxy rules: Mozilla Autoconfig and Microsoft Autodiscover expect their own subdomains (autoconfig.example.de and autodiscover.example.de) that resolve to the same host as your mail server, while the newer PACC protocol is served from the bare domain itself at https://example.de/.well-known/user-agent-configuration.json (no subdomain).
For your vhost to actually satisfy those lookups:
- DNS: add CNAME records
autoconfig.example.de and autodiscover.example.de pointing at mail.example.de.
- Apache: you need vhosts (or ServerAliases) that answer for
autoconfig.example.de, autodiscover.example.de, and, for PACC, the bare example.de domain, all proxying to Stalwart the same way your mail.example.de vhost does. Your current config only has aliases under mail..., so requests to autoconfig.example.de etc. wouldn’t be routed to Apache/Stalwart at all unless you add matching ServerName/ServerAlias entries (or a separate vhost block) covering those hostnames, with the same ProxyPass / http://127.0.0.1:8080/ rule.
- Once the hostname resolves and reaches the same reverse proxy, you don’t need special path-specific
ProxyPass rules for /jmap/session or /.well-known/jmap — your blanket ProxyPass / http://127.0.0.1:8080/ already forwards everything, including /.well-known/user-agent-configuration.json, /autodiscover/autodiscover.xml, and /mail/config-v1.1.xml, since Stalwart generates all of those automatically for any HTTPS request reaching port 443. No extra Stalwart-side configuration is required beyond the standard mail services being enabled.
So the main fix is DNS + vhost coverage for the autoconfig. and autodiscover. subdomains (and the bare domain for PACC), not the proxy rules themselves.
See Autoconfig and DNS records.
