I’m running Stalwart behind a reverse proxy (Caddy + Cloudflare) with smtp. for SMTP/IMAP (DNS-only, no Cloudflare proxy) and mail. for the admin panel and JMAP (proxied through Cloudflare).
The problem is that Stalwart is using smtp. (the default hostname) as the base URL for JMAP endpoints and OIDC redirects. When Bulwark(https://bulwarkmail.org) tries to complete OAuth login, it gets redirected to smtp. which can’t serve HTTPS since it bypasses Cloudflare, causing the flow to fail.
I need Stalwart to use https://mail. as the base URL for HTTP/JMAP/OIDC while keeping smtp. as the SMTP greeting hostname. I’ve looked through the admin panel but can’t find a separate field for this — only the default hostname under Network → General which affects SMTP greetings. The config is stored in PostgreSQL in an obfuscated format so editing it directly doesn’t seem feasible.
Is there a setting in the admin panel or config to set a separate public base URL for HTTP/JMAP/OIDC endpoints? And if not, is there perhaps a different recommended way to set up SSO with Bulwark in this kind of split-hostname setup?
