iCalendar export: RRULE contains SKIP without RSCALE (invalid per RFC 7529) when JSCalendar skip/rscale are set
When a JMAP client sets the JSCalendar recurrenceRule properties
rscale: “gregorian” and skip: “omit” (these are the RFC 8984 DEFAULT values;
real-world example: the Bulwark webmail client always sends them), Stalwart’s
iCalendar export renders the rule as e.g.
RRULE:FREQ=MONTHLY;INTERVAL=1;BYDAY=2TU;WKST=MO;SKIP=OMIT
while the rscale value is exported separately as
JSPROP;JSPTR=recurrenceRule/rscale:“gregorian”
RFC 7529 §4.1 requires: the SKIP rule part MUST NOT be specified unless the
RSCALE rule part is specified. The emitted RRULE is therefore invalid, and
strict parsers reject it (e.g. sabre/vobject: “Not supported: SKIP”), which
breaks recurrence expansion in downstream CalDAV clients.
Creating the same event WITHOUT rscale/skip produces a clean RRULE
(RRULE:FREQ=WEEKLY), so the problem is only triggered when the client sends
these (perfectly legal) JSCalendar defaults.
Either omit SKIP=OMIT/RSCALE=GREGORIAN entirely on export (they are the
defaults, semantics are identical), or emit RSCALE=GREGORIAN together with
SKIP in the RRULE so the rule stays valid per RFC 7529.
RRULE:FREQ=MONTHLY;INTERVAL=1;BYDAY=2TU;WKST=MO;SKIP=OMIT (no RSCALE)
  1. Create a recurring event via JMAP with the RFC 8984 default values set explicitly:
curl -u user:pass https://mail.example.com/jmap/
-H ‘Content-Type: application/json’
-d ‘{“using”:[“urn:ietf:params:jmap:core”,“urn:ietf:params:jmap:calendars”],
“methodCalls”:[[“CalendarEvent/set”,{“accountId”:“”,
“create”:{“t1”:{“calendarIds”:{“”:true},
“title”:“Recurring test”,“start”:“2026-07-21T19:00:00”,
“timeZone”:“Europe/Berlin”,“duration”:“PT30M”,
“recurrenceRule”:{“@type”:“RecurrenceRule”,“frequency”:“monthly”,
“interval”:1,“rscale”:“gregorian”,“skip”:“omit”,
“firstDayOfWeek”:“mo”,“byDay”:[{“day”:“tu”,“nthOfPeriod”:2}]}}}},“c1”]]}’
  1. GET the created resource via CalDAV.
  2. Observe SKIP=OMIT in the RRULE without an RSCALE part.
No relevant errors at default logging level.
This will be fixed in v0.16.14.
