Identical Inbound & Outbound Delivery Attempts Overview
The Inbound Delivery Attempts and Outbound Delivery Attempts pages in the web interface (/admin/Management/x:Trace/InboundDelivery & /admin/Management/x:Trace/OutboundDelivery) both show the same e-mails. Only the date can vary by a few seconds between them.
Inbound Delivery Attempts should show only inbound e-mails. Outbound Delivery Attempts should show only outbound e-mails.
Inbound Delivery Attempts and Outbound Delivery Attempts both show inbound and outbound e-mails.
v0.16.7
A locally-delivered message does pass through both the inbound ingest and an outbound “local” queue delivery, both logged under the same queue id, so for local-to-local mail showing up in both views can be expected rather than a duplicate.
To tell whether this is that overlap or a view that isn’t filtering: for a message that’s purely inbound-to-a-local-mailbox and one that’s relayed straight back out (no local mailbox), do the two views still show identical sets, or do they correctly diverge? And which Stalwart and web UI versions are you on? That’ll tell me whether the filters need fixing.
There are all external-to-local (or the other way around). No local-to-local.
Although the DMARC reports Stalwart sends itself automatically only show up as outbound.
Web UI is the current one. If the GitHub repo shows the newest one correctly, it should be version 1.0.4 (not sure where to find the version in the Web UI). Also still the same under Stalwart 0.16.9.
My previous reply was incomplete. It is normal and expected that a same message appears both on Inbound and Outbound delivery:
  • Inbound records when the message was accepted from either a remote host (via port 25) or by an authenticated client (via the submissions port). There should be just one record per received message there.
  • Outbound records each delivery attempt either to remote hosts or to the local store. There could be one or multiple records for each received message there as each record represents a delivery attempt.
You mentioned also that the records on each section are identical. Outbound records must start with Delivery attempt started while Inbound records with SMTP connection started. If that is not the case then there is something else going on.
The are identical in the table. The detailed records are different in the ways you described.
If inbound/outbound are only in terms of the queue and the server, the title and describtion of the pages should better reflect that.
As a user I expect it to mean inbound/outbound to the whole server like it was with the old, previuos web interface and not just related the queue.
I’m sure to just have it relate to the queue is useful in some debugging scenarios, but not just what I would expect from this overview.
