Retrying queued messages shows a timestamp of Jan 1 2000 +0 instead of time of action.
Next retry should be the current time.
Next retry shows 1999-12-31, 5:00:00 p.m. (my timezone is MDT -6)
Wait until a message is in the queue and attempt to resend it.
v0.16.24 but also occurred in previous versions.
“Retry Now” works by setting the next retry to 2000-01-01 00:00 UTC. A date in the past makes the message due immediately, and the queue picks it up straight away; what you’re looking at is that marker until the attempt runs. If delivery succeeds the message leaves the queue, and if it fails the marker is replaced by a real retry time. Showing the current time there would be less confusing, and I’d like to change that.
A message that stays at that date for more than a minute or so would be a real problem, and the queue log lines for its id would show why.
@mathias.gaertner, nothing being delivered at all on a three-node cluster is a separate issue. Please open your own topic with the queue and delivery events at debug level from the node that accepted the message.
