After upgrading from Stalwart 0.16.20 to 0.16.23, mail delivery initially works normally, but after some time delivery appears to stop completely.
The important observation is that this affects both local and remote delivery.
Messages continue to be accepted and placed into the queue, but no corresponding delivery.attempt-start events appear afterwards. The queue grows to approximately 100 messages.
After downgrading back to 0.16.20, the queued messages are processed and delivered normally.
Messages placed in the delivery queue should eventually be processed and delivered.
After running 0.16.23 for some time:
SMTP submissions are still accepted.
Incoming SMTP messages are still accepted and placed in the queue.
Outgoing messages are still accepted and placed in the queue.
However, delivery attempts stop being started.
Both local and remote delivery appear to be affected.
The queue grows while no corresponding delivery.attempt-start events are generated.
The problem does not appear to be related to a particular remote mail provider.
Immediately after starting 0.16.23, mail delivery works normally.
For example, an outgoing message was successfully delivered to Gmail:
2026-09-22T21:25:38Z INFO Queued message submission for delivery
queueId = 330998405339808768
2026-09-22T21:25:38Z INFO Delivery attempt started
2026-09-22T21:25:39Z INFO Message delivered
code = 250
2026-09-22T21:25:39Z INFO Delivery completed
Another remote delivery also completed successfully at 21:45 UTC:
2026-09-22T21:45:01Z INFO Delivery attempt started
queueId = 331000843276913152
queueName = “remote”
2026-09-22T21:45:06Z INFO Message delivered
hostname = “mx.spamexperts.com”
code = 250
2026-09-22T21:45:06Z INFO Delivery completed
2026-09-22T21:45:06Z INFO Delivery attempt ended
Later, however, messages continued to enter the queue without being processed.
For example, an incoming message was accepted at 04:47 UTC:
2026-09-23T04:47:19Z INFO Queued message for delivery
queueId = 331053968713071616
queueName = not yet assigned in this event
from = “<>”
to = [“[email protected]”]
nextRetry = 2026-09-23T04:47:19Z
There was then no delivery attempt for this message while 0.16.23 was running.
At 09:17 UTC I downgraded back to 0.16.20. Immediately afterwards the queued message was processed:
2026-09-23T09:17:14Z INFO Delivery attempt started
queueName = “local”
2026-09-23T09:17:14Z INFO Delivery completed
code = 250
The actual local delivery itself took only milliseconds:
delivery.attempt-end … elapsed = 35ms
The queued message had therefore remained unprocessed until the downgrade/restart.
The issue affects both directions:
Incoming → local mailbox
Messages are accepted by the SMTP listener and queued, but are not delivered to the local mailbox while the problem is occurring.
Authenticated submission → remote recipient
Messages submitted by authenticated users are accepted and queued, but are not delivered to remote recipients.
This makes a problem with a specific remote MX, SMTP/TLS, DNS, DANE, or MTA-STS unlikely.
There is also a startup warning:
Configuration build warning
source = “DnsResolver”
reason = “The configured DNS resolver cannot validate DNSSEC.
DANE has been disabled to avoid deferring mail.
Ensure the resolver is DNSSEC-capable and reachable over TCP.”
However, outbound delivery works normally immediately after startup, including successful SMTP/TLS delivery to Gmail and other remote MX servers. Therefore I am not currently assuming that this DNSSEC/DANE warning is the cause.
Recovery
Downgrading from 0.16.23 back to 0.16.20 immediately caused the queued messages to start processing again. The accumulated queue subsequently drained normally.
No configuration changes were made between the two versions.
