Reports to stalwart.email fail
Hello, stalwart wants to send reports to stalwart.email, however it doesn’t work, and stalwart doesn’t stop with this, it retries and retries…
I get this error message:
INFO SMTP greeting failed (delivery.greeting-failed) queueId = 326738569095822848, queueName = “default”, from = “[email protected]”, to = [“[email protected]”], size = 3563, total = 1, domain = “stalwart.email”, hostname = “mail.stalw.art”, details = “Temporary Failure for mail.stalw.art: Connection failed: Unparseable SMTP reply”
can I disable this for only the stalwart.email domain?
best regards, Stefan
You can scope a fast-expiring delivery schedule to just that recipient domain, so Stalwart stops retrying deliveries to stalwart.email without touching your report generation for anything else.
Reports going to [email protected] are ordinary outbound queue items, subject to the same routing/scheduling engine as any other outbound mail. On the MtaOutboundStrategy singleton, the schedule expression is evaluated per recipient and can branch on rcpt_domain:
  "schedule": {
    "match": [
      {"if": "rcpt_domain == 'stalwart.email'", "then": "'no-retry'"}
    "else": "'remote'"
Then define a MtaDeliverySchedule named no-retry that expires after a single attempt instead of retrying for days:
  "name": "no-retry",
  "queueId": "<MtaVirtualQueue id>",
  "retry": {"@type": "Default"},
  "notify": {"@type": "Default"},
  "expiry": {"@type": "Attempts", "maxAttempts": 1}
This makes any message queued for stalwart.email (including reports) fail fast and bounce/expire instead of retrying indefinitely, while all other outbound mail keeps using your normal remote schedule. See the Scheduling and Strategies docs for the full field reference:
what should i choose here? “report” ?
This is not normal. Can you try executing ‘telnet mail.stalw.art 25’ and paste here the response?
Are you having problems with other domains? Do you have a proxy of some kind sitting in front of your server?
Trying 2a01:4f9:c011:b43c::1…
Connected to mail.stalw.art.
Escape character is ‘^]’.
220 mail.stalw.art Stalwart ESMTP at your service
but there is this:
It looks like your IPv4 was banned by our server, if you can email your IP addresses to [email protected] we will investigate
ok. I sent you the email.
