Stalwart.email domain does not accept DMARC reports
Date		Host	Info
2026-10-28 19:12:34	Hard Bounce	mail.stalw.art [135.181.195.209]	550 5.1.1 Mailbox does not exist.
2026-10-28 19:12:25	Processed	mail.domain.tld [IPv4]	Received by mail.smtp2go.com ([email protected] -> [email protected])
Please let me know if more detailed logs are needed, I can directly send them.
$ dig +short txt _dmarc.stalwart.email
"v=DMARC1; p=reject; rua=mailto:[email protected]"
$ dig +short mx stalwart.email
10 mail.stalw.art.
This looks like a problem on the stalwart.email side, not in your own setup. Your DMARC report was delivered to mail.stalw.art, the MX for stalwart.email, and that server answered 550 5.1.1 Mailbox does not exist for [email protected]. In other words, nobody has created a postmaster account or alias for that domain on the receiving server. Your sending side did its job. SMTP2GO processed the message and handed it off correctly.
I didn’t search the docs or source for this reply, so I can’t point to any Stalwart setting that explains the rejection. The reply doesn’t depend on your version. You’re running v0.16.x, and the answer for v1.0 may differ. If you do upgrade, the guide is here: Overview | Stalwart
The rua address in the stalwart.email DMARC record didn’t point at a mailbox that existed on our server, so every aggregate report bounced. That’s fixed now, and reports to [email protected] should be accepted from here on. If your next one still bounces, post the new bounce line here and I’ll take another look.
I have two examples of this from after your comment. Both say:
<[email protected]>: host mail.stalw.art[135.181.195.209] said: 550
    5.1.1 Mailbox does not exist. (in reply to RCPT TO command)
One sent Sat, 31 Oct 2026 01:15:29 +0000 (UTC), the other Mon, 02 Nov 2026 01:09:37 +0000 (UTC).
