Incomplete results for emails containing attachments in JMAP query
The JMAP query (using jmap-client-ts):
const query = await client.email_query({
			accountId: "f",
			filter: {
				hasAttachment: true
			limit: 2000,
			calculateTotal: true
Returns incomplete results (only 32 emails instead of > 100) in my scenario. I am not quite sure whether this is really a bug or a broken database on my site.
Stalwart should return all emails containing attachments.
Stalwart returns exactly 32 emails. The weird thing is that most of them are relatively recent, then there is a huge gap, and the last few are from August 2025.
  1. Setup Stalwart
  2. Have some emails in an inbox
  3. Use the provided TypeScript file
The same happens when using GitHub - root-fr/jmap-webmail: Modern JMAP webmail client built for Stalwart Mail Server. Privacy-focused, responsive, with real-time updates. · GitHub as a webmail client. Filtering for emails containing attachments only returns 32 emails (the same).
Script:
import { Client } from 'jmap-client-ts';
interface Transport {
    get<ResponseType>(url: string, headers: { [headerName: string]: string }): Promise<ResponseType>;
    post<ResponseType>(url: string, content: unknown, headers: { [headerName: string]: string }): Promise<ResponseType>;
const transport: Transport = {
    get: async <ResponseType>(url: string, headers: { [headerName: string]: string }) => {
        const response = await fetch(url, { method: 'GET', headers });
        if (!response.ok) {
            throw new Error(`GET ${url} failed with status ${response.status}`);
        return (await response.json()) as ResponseType;
    post: async <ResponseType>(url: string, content: unknown, headers: { [headerName: string]: string }) => {
            method: 'POST',
            headers: {
                'Content-Type': 'application/json',
                ...headers
            body: JSON.stringify(content)
        if (!response.ok) {
            throw new Error(`POST ${url} failed with status ${response.status}`);
async function markEmailsWithAttachmentsAsUnread() {
    const API_TOKEN = process.env.JMAP_TOKEN || 'YOUR_ACCESS_TOKEN_HERE';
    const SESSION_URL = 'https://HOST/.well-known/jmap';
    const client = new Client({
        accessToken: API_TOKEN,
        sessionUrl: SESSION_URL,
        transport
    await client.fetchSession();
    const emailIds: string[] = [];
    let position = 0;
    while (true) {
            accountId: "f",
            filter: {
                hasAttachment: true
            position: position,
            limit: 2000,
        emailIds.push(...query.ids);
        position += query.ids.length;
        if (query.ids.length === 0 || (query.total !== undefined && emailIds.length >= query.total)) {
            break;
    if (emailIds.length === 0) {
        console.log('No emails with attachments found.');
        return;
    const update = Object.fromEntries(
        emailIds.map((id) => [id, { 'keywords/$seen': null }])
    await client.email_set({
        accountId: "f",
        update
    console.log(`Successfully marked ${emailIds.length} email(s) as unread.`);
markEmailsWithAttachmentsAsUnread().catch((error) => {
    console.error('Error while marking emails as unread:', error);
    process.exitCode = 1;
Let me research how Stalwart handles the hasAttachment filter and any related indexing behavior.
The CHANGELOG is very helpful. I can see two highly relevant items:
  1. In the v0.16.0 section: JMAP: Fix hasAttachment search field (#2778) - meaning hasAttachment search indexing was broken before 0.16.0 and was fixed in 0.16.0.
  2. In v0.15.3: PostgreSQL search: Truncate emails to 650kb for full-text search indexing.
Now let me check if there’s a re-indexing capability that could help fix stale/missing FTS index data:
This is a known bug that was fixed in the codebase. The CHANGELOG entry under v0.16.0 explicitly lists: Fix hasAttachment search field (#2778). If you are on an earlier build of the v0.16.x line (before this fix landed), upgrading to the latest image should resolve the incorrect hasAttachment filter results.
Additionally, because the hasAttachment field is stored in the FTS/search index, emails that were indexed before the fix may still have stale or missing index entries. After upgrading, you can force a full re-index by creating a StoreMaintenance task with maintenanceType: reindexAccounts. This can be triggered from:
  • WebUI: Management › Tasks, create a StoreMaintenance task
  • CLI: stalwart-cli create task/StoreMaintenance
  • JMAP API: x:Task/set with a create argument for the StoreMaintenance variant
The reindexAccounts maintenance type is documented as “Reindex all accounts’ data for search”, which will rebuild the hasAttachment boolean field for all messages.
References:
The hasAttachment flag is computed from MessageMetadata at ingest and stored in the index; older messages that pre-date that index field never had it set, which is why your query is finding a sliver of recent messages plus a few stragglers. The fix is to reindex the account: from the admin UI, Tasks → Perform account maintenance → pick “Reindex”. You can also do it via stalwart-cli or by hitting the maintenance endpoint directly. After it finishes, hasAttachment should return the full set.
There is no actual cap of 32 anywhere in the query path, so we can rule out a pagination or limit bug; it is purely the index being incomplete on legacy messages.
