Installation issues (v0.16.5)
I have tried to install Stawart at an Ubuntu server, but following the instructions at the website are different from the behavior I see. After the installation Stalwart is always running on a different port. When trying to reach /admin to make the first configuration, only emails are accepted. I’ve tryed different configurations, the only possibility of get it running on port 8080 is if I activate the recovery mode, but still, I cant configure with the initial login data provided.
Is there anything I am missing?
I was expecting the instalattion to be exactly as the instructions.
I cant get to the initial configuration screen
  1. install
  2. Get the login data at the logs
  3. Access http://myip:38891/admin (38891 this is the one at the moment)
  4. The page is running forever, or, if it is configured at the webserver, it takes me to the login screen that only accepts emails to login
SQLite
SQLite
Let me look into the installation and initial login process for Stalwart.
There are a few separate issues going on here. Let me address each one:
1. The port keeps changing
On first start, Stalwart runs in bootstrap mode using port 8080. The port you’re seeing (e.g. 38891) is almost certainly a random ephemeral port being shown somewhere unrelated – or the server has been restarted multiple times and is in a different state. The bootstrap HTTP listener is always on 8080. Access the setup wizard at:
http://<your-server-ip>:8080/admin
2. Login only accepts email addresses
This is the key symptom: after the setup wizard has run at least once, Stalwart provisions a permanent administrator account whose username is an email address (e.g. [email protected]) – that is normal and expected. However, during the initial bootstrap mode (before the wizard is completed), the username is simply admin (no domain) and the password is the 16-character temporary password printed exactly once in the service logs.
To retrieve the bootstrap credentials on systemd:
sudo journalctl -u stalwart -n 200 | grep -A8 'bootstrap mode'
The credentials block looks like:
username: admin
password: XXXXXXXXXXXXXXXX
3. Recovery mode still doesn’t work
Recovery mode re-enables the port 8080 HTTP listener and accepts credentials from the STALWART_RECOVERY_ADMIN environment variable set in /etc/stalwart/stalwart.env. Make sure you have set that variable before starting in recovery mode, and are using exactly the username and password you put there. Recovery mode is enabled by also setting STALWART_RECOVERY_MODE=1 in that same env file.
The likely root cause of your situation: the setup wizard may have already completed (explaining why login now expects an email address), but you did not capture the final screen’s generated admin@<domain> credentials. In that case, use STALWART_RECOVERY_ADMIN=admin:somepassword in /etc/stalwart/stalwart.env and restart with STALWART_RECOVERY_MODE=1 – then sign in at http://<ip>:8080/admin with those exact credentials.
Full installation docs for Linux: Linux / MacOS | Stalwart
Are you running Stalwart as root or with CAP_NET_BIND_SERVICE? If not, it might explain the random port because it cannot bind below port 1024, which requires additional permissions on Linux.
Thank you very much for your help! AI helped me to get through and it is already working! Now I wonder why there are some open ports that I did not find any description about what they do: ports 36581 and 43421. I have just blocked them on ufw, but I could not figure out what they are needed for.
