JMAP download returns 404 for directly-shared FileNode blobs despite mayRead = true (works when shared via parent folder)
When a FileNode is shared directly with another user, the recipient can see the file via FileNode/get (with myRights.mayRead = true), but downloading the blob through /jmap/download/... returns 404 Not Found. The owner can download the same blob fine, and the recipient can also download it if the parent folder is shared instead of the file itself. This points to a difference in the download-path ACL evaluation between directly-shared files and files accessed through a shared folder.
The file under test:
  • id = fileId123
  • blobId = blobId123
  • name = file.txt
  • type = text/plain
  • located in sharedAccount
When a recipient has read access to a FileNode (confirmed by FileNode/get returning the file with myRights.mayRead = true), the associated blob should be downloadable via /jmap/download/{accountId}/{blobId}/{name}, returning 200 OK — regardless of whether access was granted by sharing the file directly or by sharing a parent folder.
Case A — file shared directly:
  • FileNode/get (recipient): file is visible, myRights.mayRead = true
  • GET /jmap/download/sharedAccount/blobId123/file.txt?accept=text/plain → 404 Not Found
  • Same request as the owner → 200 OK (so the blob exists)
    Case B — file inside a shared folder:
  • GET /jmap/download/sharedAccount/blobId123/file.txt?accept=text/plain (recipient) → 200 OK
Using an arbitrary file name in the URL still returns 404 in Case A, so the failure is not related to the {name} segment.
  1. As [email protected] (account ownerAccount), create a FileNode in sharedAccount with id = fileId123, blobId = blobId123, name = file.txt, type = text/plain.
  2. Share that file directly with [email protected] (account recipientAccount).
  3. As the recipient, call FileNode/get for the file → file is returned, myRights.mayRead = true.
  4. As the recipient: GET /jmap/download/sharedAccount/blobId123/file.txt?accept=text/plain → 404 Not Found.
  5. As the owner, issue the same download request → 200 OK.
  6. Remove the direct share. Place the file inside a folder (folderId123) and share the folder with the recipient.
  7. As the recipient, issue the same download request → 200 OK.
Meilisearch
Optional hypothesis (not confirmed): the blob-access check on the download path for FileNode-linked blobs may resolve items reachable through a shared folder/hierarchy but not items shared individually. Workaround: share the parent folder instead of the file directly, which makes the JMAP download succeed (200 OK).
Let me look into the blob download ACL logic in the Stalwart server source code to understand how download access is checked for FileNode blobs.
So, what did you get? @helpbot
This has been fixed. The fix will be included in v0.16.7.
