State returned from FileNode/get is not the current state
FileNode/get should return the state on the server of all FileNode records, but the state returned is out of date.
See the FileNode/get expected response behavior from the JMAP spec.
The state returned is older than the current state.
Request:
    "using": [
        "urn:ietf:params:jmap:core",
        "urn:ietf:params:jmap:filenode"
    "methodCalls": [
            "FileNode/get",
                "accountId": "c",
                "ids": null,
                "properties": [
                    "id",
                    "name",
                    "parentId",
                    "nodeType",
                    "modified",
                    "size",
                    "blobId",
                    "type"
            "nodes"
Response:
    "methodResponses": [
            "FileNode/get",
                "accountId": "c",
                "state": "sei",
                "list": [
                        "id": "be",
                        "name": "apple.md",
                        "parentId": null,
                        "nodeType": "file",
                        "modified": "2026-06-02T14:02:15Z",
                        "size": 56,
                        "blobId": "cbrij9timsflhxzbidww1i7uq19soc3hib31x0iy99jnyyitsknkwaqmeq",
                        "type": "application/octet-stream"
                        "id": "bf",
                        "name": "banana.md",
                        "parentId": null,
                        "nodeType": "file",
                        "size": 38,
                        "blobId": "caq1s9yh1uz1gvtwl2npak2ujelu7dpit91w7rbyfn7dqv7mefxgsaqmeu",
                "notFound": []
            "nodes"
    "sessionState": "9f3fd14e"
The returned state is “sei”.
Now, without making any changes, request all changes since “sei”. There shouldn’t be any, because “sei” was just returned, so it should be the current state.
Request:
    "using": [
    "methodCalls": [
            "FileNode/changes",
                "accountId": "c",
                "sinceState": "sei",
                "maxChanges": null
            "changes"
            "FileNode/get",
                "accountId": "c",
                "#ids": {
                    "resultOf": "changes",
                    "name": "FileNode/changes",
                    "path": "/created"
                "properties": [
                    "id",
                    "name",
                    "parentId",
                    "nodeType",
                    "modified",
                    "size",
                    "blobId",
                    "type"
            "created"
            "FileNode/get",
                "accountId": "c",
                "#ids": {
                    "path": "/updated"
                "properties": [
                    "id",
                    "name",
                    "parentId",
                    "nodeType",
                    "modified",
                    "size",
                    "blobId",
                    "type"
            "updated"
Response:
            "FileNode/changes",
                "accountId": "c",
                "oldState": "sei",
                "newState": "sjq",
                "hasMoreChanges": false,
                "created": [
                    "be",
                    "bf"
                "updated": [],
                "destroyed": [
                    "w",
                    "z",
                    "s",
                    "k",
                    "j",
                    "t",
                    "o",
                    "m",
                    "l",
                    "n",
                    "u",
                    "r",
                    "q",
                    "p",
                    "i",
                    "c",
                    "bb",
                    "bc",
                    "3",
                    "1",
                    "0",
                    "2",
                    "7",
                    "v",
                    "y",
                    "f",
                    "g",
                    "e",
                    "h",
                    "ba",
                    "x",
                    "d",
                    "9",
                    "b"
            "changes"
            "FileNode/get",
                "accountId": "c",
                "state": "sei",
                "list": [
                        "id": "be",
                        "name": "apple.md",
                        "parentId": null,
                        "nodeType": "file",
                        "size": 56,
                        "id": "bf",
                        "parentId": null,
                        "nodeType": "file",
                        "size": 38,
                "notFound": []
            "created"
            "FileNode/get",
                "accountId": "c",
                "state": "sei",
                "list": [],
                "notFound": []
            "updated"
Notice that oldState is “sei” and newState is “sjq”.
Before setting up this test with just two files for the bug report, I had deleted all folders and files using the File Manager with a WebDAV connection to Stalwart. The list of destroyed nodes refers to all those old folders and files.
When I first asked for all the ids in this new session, FileNode/get said the current state was “sei”, but according to FileNode/changes, the current state is “sjq”.
Notice also that the state in the two FileNode/get responses for the created and updated nodes. Again, it is reporting the curent state to be “sei”, when FileNode/changes has just told me that newState is “sjq”.
This has been fixed on the main branch. The fix will be included in v0.16.8.
