JMAP EventSource ping events report their interval value in milliseconds rather than seconds.
Stalwart converts the requested ping interval to milliseconds for the internal timer, but then serializes that converted value directly into the SSE ping payload.
For example, a 30-second ping interval is emitted at the correct time but reports:
event: ping
data: {"interval": 30000}
RFC 8620 §7.3 specifies that the interval in a ping event is in seconds.
A 30-second interval should therefore report:
event: ping
data: {"interval": 30}
The ping occurs at the correct interval, but its advertised value is multiplied by 1000.
For example, ping=30 reports 30000. In test mode, ping=1 produces:
event: ping
data: {"interval": 1000}
instead of 1.
- Connect to the authenticated JMAP
eventSourceUrladvertised in the Session object. - Set
ping=30, for example withtypes=*andcloseafter=no. - Wait for the ping event.
- Observe that it reports
"interval": 30000rather than"interval": 30.
No error is logged. The EventSource connection remains valid; only the protocol value in the ping event is incorrect.
Built from source
