When applying a fresh config via CLI, the LDAP directory doesn’t seem to be picked up right away (even after refresh actions).
It seems like a server (container) reboot is necessary.
I should be able to login with a user from an LDAP directory right after refresh actions.
Valid username/password combination is rejected until the server is rebooted.
- Start with a fresh stalwart server with LDAP
- Apply the config below
- Try to login to an account via thunderbird (username/password invalid error).
- Restart server
- Same combination is now accepted.
ERROR Authentication error (auth.error) listenerId = "http", localPort = 8080, remoteIp = 10.42.0.192, remotePort = 57030, reason = "Failed to decode token. If you are using an external OIDC provider, make sure it is configured as the default directory under the Authentication object.", causedBy = "crates/common/src/auth/oauth/token.rs:87", details = "sw1.6omL5BgjUT9kwC7qumphA8wS6vSFu5dlihRq2-58SjRaI95eFLLIAxJ3AKCn.YWRtaW4", remoteIp = 192.168.1.190
LDAP
config:
{"@type":"upsert","object":"Tracer","value":{"otel":{"@type":"OtelHttp","enable":true,"enableLogExporter":false,"enableSpanExporter":true,"endpoint":"http://tempo.kube-system.svc.cluster.local:4318/v1/traces","httpAuth":{"@type":"Unauthenticated"},"level":"trace"},"stdout":{"@type":"Stdout","level":"info"}},"matchOn":["@type"]}
{"@type":"update","object":"Metrics","value":{"openTelemetry":{"@type":"Disabled"},"prometheus":{"@type":"Enabled","authSecret":{"@type":"None"}}}}
{"@type":"update","object":"DataStore","value":{"@type":"PostgreSql","authSecret":{"@type":"EnvironmentVariable","variableName":"POSTGRESQL_PASSWORD"},"authUsername":"stalwart","database":"stalwart","host":"postgresql-primary"}}
{"@type":"update","object":"SearchStore","value":{"@type":"PostgreSql","authSecret":{"@type":"EnvironmentVariable","variableName":"POSTGRESQL_PASSWORD"},"authUsername":"stalwart","database":"stalwart","host":"postgresql-primary"}}
{"@type":"update","object":"BlobStore","value":{"@type":"S3","accessKey":{"@type":"EnvironmentVariable","variableName":"BUCKET_ACCESS_KEY"},"bucket":"stalwart","region":{"@type":"Custom","customEndpoint":"http://minio","customRegion":"us-east-1"},"secretKey":{"@type":"EnvironmentVariable","variableName":"BUCKET_SECRET_KEY"},"securityToken":{"@type":"None"},"sessionToken":{"@type":"None"}}}
{"@type":"upsert","object":"Directory","value":{"authentik":{"@type":"Ldap","attrClass":{"objectClass":true},"attrDescription":{"sAMAccountName":true},"attrEmail":{"mail":true},"attrEmailAlias":{"mailAlias":true},"attrMemberOf":{"memberOf":true},"attrSecretChanged":{"pwdChangedTime":true},"baseDn":"dc=belfodil,dc=ca","bindDn":"cn=ldapservice,dc=belfodil,dc=ca","bindSecret":{"@type":"EnvironmentVariable","variableName":"LDAP_BIND_PASSWORD"},"description":"Authentik LDAP","filterLogin":"(|(mail=?)(mailAlias=?)(recoveryEmail=?))","filterMailbox":"(|(mail=?)(mailAlias=?)(recoveryEmail=?))","filterMemberOf":"(\u0026(objectClass=posixGroup)(cn=?))","url":"ldap://ak-outpost-ldap-outpost:389"}},"matchOn":["@type"]}
{"@type":"update","object":"Authentication","value":{"directoryId":"#authentik"}}
{"@type":"upsert","object":"Domain","value":{"default":{"name":"mydomain.com"},"dkimManagement":{"@type":"Manual"}},"matchOn":["name"]}
{"@type":"update","object":"SystemSettings","value":{"defaultDomainId":"#default","defaultHostname":"mail.mydomain.com"}}
{"@type":"upsert","object":"NetworkListener","value":{"imaps":{"bind":{"[::]:993":true},"name":"imaps","overrideProxyTrustedNetworks":{"10.0.0.0/8":true,"103.21.244.0/22":true,"103.22.200.0/22":true,"103.31.4.0/22":true,"104.16.0.0/13":true,"104.24.0.0/14":true,"108.162.192.0/18":true,"131.0.72.0/22":true,"141.101.64.0/18":true,"162.158.0.0/15":true,"172.16.0.0/12":true,"172.64.0.0/13":true,"173.245.48.0/20":true,"188.114.96.0/20":true,"190.93.240.0/20":true,"192.168.0.0/16":true,"197.234.240.0/22":true,"198.41.128.0/17":true,"2400:cb00::/32":true,"2405:8100::/32":true,"2405:b500::/32":true,"2606:4700::/32":true,"2803:f800::/32":true,"2a06:98c0::/29":true,"2c0f:f248::/32":true},"protocol":"imap","tlsImplicit":true},"pop3s":{"bind":{"[::]:995":true},"name":"pop3s","overrideProxyTrustedNetworks":{"10.0.0.0/8":true,"103.21.244.0/22":true,"103.22.200.0/22":true,"103.31.4.0/22":true,"104.16.0.0/13":true,"104.24.0.0/14":true,"108.162.192.0/18":true,"131.0.72.0/22":true,"141.101.64.0/18":true,"162.158.0.0/15":true,"172.16.0.0/12":true,"172.64.0.0/13":true,"173.245.48.0/20":true,"188.114.96.0/20":true,"190.93.240.0/20":true,"192.168.0.0/16":true,"197.234.240.0/22":true,"198.41.128.0/17":true,"2400:cb00::/32":true,"2405:8100::/32":true,"2405:b500::/32":true,"2606:4700::/32":true,"2803:f800::/32":true,"2a06:98c0::/29":true,"2c0f:f248::/32":true},"protocol":"pop3","tlsImplicit":true},"smtp":{"bind":{"[::]:25":true},"name":"smtp","overrideProxyTrustedNetworks":{"10.0.0.0/8":true,"103.21.244.0/22":true,"103.22.200.0/22":true,"103.31.4.0/22":true,"104.16.0.0/13":true,"104.24.0.0/14":true,"108.162.192.0/18":true,"131.0.72.0/22":true,"141.101.64.0/18":true,"162.158.0.0/15":true,"172.16.0.0/12":true,"172.64.0.0/13":true,"173.245.48.0/20":true,"188.114.96.0/20":true,"190.93.240.0/20":true,"192.168.0.0/16":true,"197.234.240.0/22":true,"198.41.128.0/17":true,"2400:cb00::/32":true,"2405:8100::/32":true,"2405:b500::/32":true,"2606:4700::/32":true,"2803:f800::/32":true,"2a06:98c0::/29":true,"2c0f:f248::/32":true},"protocol":"smtp","useTls":false},"smtps":{"bind":{"[::]:465":true},"name":"submissions","overrideProxyTrustedNetworks":{"10.0.0.0/8":true,"103.21.244.0/22":true,"103.22.200.0/22":true,"103.31.4.0/22":true,"104.16.0.0/13":true,"104.24.0.0/14":true,"108.162.192.0/18":true,"131.0.72.0/22":true,"141.101.64.0/18":true,"162.158.0.0/15":true,"172.16.0.0/12":true,"172.64.0.0/13":true,"173.245.48.0/20":true,"188.114.96.0/20":true,"190.93.240.0/20":true,"192.168.0.0/16":true,"197.234.240.0/22":true,"198.41.128.0/17":true,"2400:cb00::/32":true,"2405:8100::/32":true,"2405:b500::/32":true,"2606:4700::/32":true,"2803:f800::/32":true,"2a06:98c0::/29":true,"2c0f:f248::/32":true},"protocol":"smtp","tlsImplicit":true}},"matchOn":["name"]}
{"@type":"update","object":"Http","value":{"useXForwarded":true}}
{"@type":"upsert","object":"Certificate","value":{"default":{"certificate":{"@type":"File","filePath":"/opt/stalwart/etc/certs/tls.crt"},"privateKey":{"@type":"File","filePath":"/opt/stalwart/etc/certs/tls.key"}}},"matchOn":["certificate"]}
{"@type":"update","object":"Email","value":{"compressionAlgorithm":"lz4"}}
{"@type":"update","object":"MtaStageAuth","value":{"require":{"else":"listener != 'smtp'"},"saslMechanisms":{"else":"[plain, login]"}}}
{"@type":"upsert","object":"MtaRoute","value":{"relay":{"@type":"Relay","address":"email-smtp.us-east-1.amazonaws.com","authSecret":{"@type":"EnvironmentVariable","variableName":"SMTP_PASSWORD"},"authUsername":"AKIA2UC3CZ4IUGTQWQ4L","implicitTls":false,"name":"relay","port":587,"protocol":"smtp"}},"matchOn":["name"]}
{"@type":"upsert","object":"MtaVirtualQueue","value":{"remote":{"name":"remote"}},"matchOn":["name"]}
{"@type":"upsert","object":"MtaDeliverySchedule","value":{"relay":{"expiry":{"@type":"Ttl"},"name":"relay","notify":{"@type":"Default"},"queueId":"#remote","retry":{"@type":"Custom","intervals":{"0":{"duration":120000},"1":{"duration":300000},"2":{"duration":600000},"3":{"duration":900000},"4":{"duration":1800000},"5":{"duration":3600000},"6":{"duration":7200000}}}}},"matchOn":["name"]}
{"@type":"update","object":"MtaOutboundStrategy","value":{"route":{"else":"'relay'"},"schedule":{"else":"'relay'"}}}
{"@type":"update","object":"SpamClassifier","value":{"model":{"@type":"FtrlFh"}}}
{"@type":"upsert","object":"SpamRule","value":{"aws_ses_flagged":{"@type":"Header","condition":{"else":"''","match":{"0":{"if":"(name_lower == 'x-ses-spam-verdict' || name_lower == 'x-ses-virus-verdict') \u0026\u0026 contains(value_lower, 'fail')","then":"'AWS_SES_FLAGGED'"}}},"description":"Trust AWS SES Spam and Virus verdicts","name":"AWS_SES_FLAGGED"}},"matchOn":["name"]}
{"@type":"upsert","object":"SpamTag","value":{"ses_flagged":{"@type":"Score","score":1000,"tag":"AWS_SES_FLAGGED"}},"matchOn":["tag"]}
{"@type":"create","object":"Action","value":{"reload_certificates":{"@type":"ReloadTlsCertificates"},"reload_settings":{"@type":"ReloadSettings"}}}
