List only users with stalwart-cli
I’m trying to create a dynamically mailing list with all the users from the servers. In order to do this I’m thinking to create a script which is listing the users with stalwart-cli and updating the mailing list.
I couldn’t found out how to filter only users in Account query. Is it possible?
Thanks,
Andrei
Let me look up the CLI account commands and how filtering works.
Based on the docs, the x:Account/query filter does not expose a type or role condition directly - the supported filter conditions are only text, name, domainId, memberTenantId, and memberGroupIds. There is no --where type=User equivalent in the CLI query for accounts.
However, there are two practical workarounds:
Option 1: Use stalwart-cli describe Account to confirm available filters
Run this first to see exactly what filter keys your version exposes:
Look at the Filters: section output. If a type/variant filter isn’t listed, you’ll need the approach below.
Option 2: Post-filter with jq on the roles field
Since accounts are created with "roles": {"@type": "User"} (vs "@type": "Admin" or "@type": "Group"), you can fetch all accounts with --json and filter in jq:
stalwart-cli query Account --fields id,name,roles --json \
  | jq -r 'select(.roles["@type"] == "User") | .name'
This streams all accounts and keeps only those whose roles variant is User, which you can then pipe into your mailing list update script.
Option 3: Use memberGroupIds filter (if users share a group)
If all regular users are members of a specific group, you can filter by that:
stalwart-cli query Account --where memberGroupIds=<group-id> --json
The query docs are at: Searching and listing | Stalwart and the Account object reference (including all supported filter conditions) is at: Account | Stalwart
Thanks helpbot.
It is working.
Just to follow up on this, while it is not documented as a filter when running describe Account, you can actually use --where @type=User and it works.
In case the dev reads this and views it as undocumented behaviour, please don’t remove it, it’s fantastically useful and saves a lot of inefficient post filtering work. In general I wish there were more filters, for example to find a User by their email address I can’t filter with --where emailAddress=... because I get the error:
error: jmap error: unsupportedFilter: Filter on property emailAddress is not supported or invalid
Instead I need to first find the Domain with a query and then query Account with --where name=... --where DomainId=... --where @type=User. It’s a multistep process for a simple query. If I couldn’t also filter by @type that would mean another step to remove Groups.
