Local traffic triggering http.x-forwarded-missing warning
I have stalwart behind a reverse proxy and have it configured with reading x-forwarded-for headers. I noticed I’m getting warnings in the log file that relate to local port 443 (caddy uses 8080) and remoteIp 127.0.0.1 which is localhost, so I’m assuming, there is some internal traffic hitting port 443, which triggers the warning.
Since this occurs every 30s, it leads me to believe this is some periodic check or something?
No warnings in the log file.
Warning in the log file every 30 seconds
  1. Configure stalwart to obtain client IP from x-forwarded-for headers
  2. Run stalwart (docker)
  3. Observe log output
2026-05-11T07:07:52Z WARN X-Forwarded-For header is missing (http.x-forwarded-missing) listenerId = “https”, localPort = 443, remoteIp = 127.0.0.1, remotePort = 60528
Let me research this to give you an accurate answer.
The situation is clear. Here’s what’s happening and what you can do about it:
Root cause: Stalwart’s /healthz/live and /healthz/ready endpoints are being polled every ~30 seconds (likely by Docker’s own health check or Caddy’s upstream health checking). These requests come from 127.0.0.1 with no X-Forwarded-For header, so Stalwart correctly fires the http.x-forwarded-missing warning because you have use_forwarded enabled.
This is expected behavior – it’s not a bug, just an internal health-check probe bypassing the reverse proxy. The server still falls back to the real connection IP (127.0.0.1) and handles the request normally.
To silence the warning, you can exclude the http.x-forwarded-missing event from your tracer. In the WebUI, go to Settings › Telemetry › Tracers, edit your tracer, and add http.x-forwarded-missing to the Events list with the policy set to Exclude. The relevant tracer fields are:
  • events: ["http.x-forwarded-missing"]
  • eventsPolicy: "exclude"
This tells the tracer to suppress that specific event type while logging everything else normally.
Relevant docs: Tracer object reference and Telemetry / Tracing
The next Docker images will include X-Forwarded-For headers when accessing the healthz endpoint.
The fix is already in the pipeline — the next Docker images will include X-Forwarded-For headers on the /healthz health check requests, so the warning will stop appearing automatically once you update.
In the meantime, the workaround of excluding http.x-forwarded-missing from your tracer (as described above) remains valid if you want to silence the warning before then.
