Proxy header ignored
Using Apache as HTTP proxy for port 443.
Correct IP to be shown in logs as I log in.
127.0.0.1 is logged.
I have confirmed all the relevant headers are reaching Stalwart using tcpdump. HTTP is configured correctly, it is supposed to use the X-Forwarded-For header.
Let me look up the proxy/trusted IP configuration in Stalwart’s docs.
The useXForwarded setting defaults to false, which is why Stalwart is ignoring the X-Forwarded-For header and logging 127.0.0.1 instead.
You need to enable the useXForwarded flag on the Http singleton. You can do this in the WebUI under Settings > Network > HTTP > General, or via the CLI:
stalwart-cli update Http --field useXForwarded=true
Two important caveats from the docs:
  1. This flag should only be enabled when Stalwart is actually behind a trusted proxy. Because untrusted clients could forge these headers, enabling it on a directly-exposed server would let anyone spoof their source IP for logging and access-control purposes.
  2. Do not use useXForwarded together with the Proxy Protocol. They serve the same purpose and are not interchangeable on the same listener – pick one.
Since you are using Apache in HTTP mode forwarding to Stalwart, useXForwarded is the correct mechanism (Proxy Protocol is for TCP-layer proxies). Once enabled, Stalwart will read the client IP from the X-Forwarded-For / Forwarded header that Apache is already sending.
References: HTTP Settings docs and Reverse Proxy Overview.
I did set that option ON in the GUI. I don’t have stalwart-cli.
Now with CLI:
ProxyObtain remote IP from Forwarded header: Yes
