Mailing list local recipients with sub-addressing causes mailbox not found errors
When adding recipients to a mailing list that exist locally, but you add a sub address with +test (domain is enabled for sub-addressing) the mails are not delivered to the local mailbox and instead are bounced with 5.5.0, Message: Mailbox not found.
The email should be delivered to the user mailbox with the sub address so the user can perform additional filtering or sieve scripting. NOTE: I am aware that you can also achieve this via to header that will be mailing list. However, it feels weird that these sub addresses are bounced while sending directly to this address does work.
For each local recipient with a sub address the message is rejected with 5.5.0, Message: Mailbox not found.
  1. Default stalwart setup
  2. Create a domain with sub-addressing enabled (default)
  3. Create an account
  4. Create a mailing list with the account from step 3 and add the account from step 3 with a sub address as recipient
  5. Send email to the mailing list
stalwart-6c7cfdbd76-wv562 2026-08-10T20:30:45Z INFO DSN permanent failure notification (delivery.dsn-perm-fail) queueId = 323200149343964161, queueName = "local", from = "[email protected]", to = ["[email protected]", "[email protected]", "[email protected]"], size = 9680, total = 5, to = "[email protected]", hostname = "localhost", details = "Unexpected response for RCPT TO:<[email protected]>: Code: 550, Enhanced code: 5.5.0, Message: Mailbox not found.", total = 0
stalwart-6c7cfdbd76-wv562 2026-08-10T20:30:45Z INFO DSN success notification (delivery.dsn-success) queueId = 323200149343964161, queueName = "local", from = "[email protected]", to = ["[email protected]", "[email protected]", "[email protected]"], size = 9680, total = 5, to = "[email protected]", hostname = "localhost", code = 250, details = "OK"
External recipients with a sub address works fine (which makes a lot of sense).
There might be some links with Domain aliases not (automatically) working for mailing lists for said domain
