Domain aliases not (automatically) working for mailing lists for said domain
When sending an email to a mailing list called [email protected] for the main domain example.tld with alias domain example.alt, the connection is excepted but rejected with relay not allowed
INFO Relay not allowed (smtp.relay-not-allowed) listenerId = "smtp", localPort = 25, remoteIp = <REDACTED>, remotePort = 40953, to = "[email protected]"
The email should be delivered properly to the mailing list
The email is rejected with Relay not allowed
  1. Standard Stalwart instance
  2. Add a domain
  3. Add to the domain from step 2 an alias domain
  4. Create mailing list on domain from step 2
  5. Send to the mailing list via the alias domain
Sending to a user account via the domain alias does work, so it seems to be a problem with mailing list handling.
Actually, it also does not work for normal user accounts.
As in for domain example.com with alias alias.com and user [email protected]. If you send an email to [email protected], you will get a mailbox not found error.
This is also not something that you can fix, with adding an extra alias to your [email protected] account as the alias domain is not a real domain.
@stalwart is this a user error for alias domains?
Somebody made a PR for exactly this issue (auto closed because of current contribution guidelines)
