When sending an email to a recipient domain protected by a MTA-STS policy the MX/MTAhost certificate is not validated as required in RFC 8461 Section 4.2 but only opportunistic TLS encryption is enforced.
The email should fail to be delivered when the recipient mailserver does not present a matching (DNS SAN to MX and time valid, as well as chaining up to a locally trusted CA) TLS certificate. An NDR as well as a TLS report should be sent.
The mail is tried to deliver and StartSSL fails due to the invalid certificate. It is then rescheduled to be sent via the tls-invalid TLS strategywhich allows invalid certificates even for MTA-STS protected domains
Set stalwart TLS Strategy MTA-STS to optional or required. Send a mail to measurement@mail-mtasts-rn-iv.measurement.email-security-scans.org
OIDC
Edit: Further observation:
When checking the documentation at MTA-STS | Stalwart I came to the conclusion that this is extruded/generated text and not checked by anyone knowing about MTA-STS. I conclude this from this sentence: “The receiving email server will retrieve the MTA-STS policy statement and verify that the incoming connection meets the security requirements specified in the policy.” → First this isn’t how it’s done at all (inbound vs outbound, policy doesn’t specify security requirements etc.) and second it’s useless for anyone configuring stalwart and referring to the documentation, as it does not explain how it is implemented within stalwart.
Please don’t take this last part as negative feedback on stalwart or the people working on it. It’s just feedback for you to consider when writing documentation as what can happen and what is helpful (or counterproductive) for the users.
