Oauth client with OIDC directory
With enabled OIDC directory and using a Oauth2 client with the device code flow the login screen presented requires email+password+device code.
Because of the OIDC directory I’d expect no password field
Password is required for to connected the Oauth client
OIDC
Let me research how Stalwart handles the OAuth2 device code flow with an OIDC directory backend.
I do not understand what the issue is. If you are using an external OIDC you need to use the device auth flow of your IdP, not Stalwart’s.
My bad. I draw the wrong conclusion about what token the endpoints want.
The autodiscovery of the client just went of “www-authenticate: Bearer realm=“Stalwart Server”” of the returned endpoint headers and tried to do Oauth/OIDC against the servers well-known oidc document which is obviously Stawart IDP. It did not use the PACC draft to figure out how to authenticate so it probably guessed Oauth based on the “Bearer” in the www-authenticate.
