I do have some failed “DNS management” tasks. I can edit them, but I don’t seem to have any possibility to “retry” or “reschedule” them. Might it be possible to add the option in the edit menu to reschedule a failed task to try it again (for the DNS after a server update since it was a problem with the dns-update that should be fixed after the update).
Is this not the same as currently available at the Failed Tasks list?
If i look at failed tasks, you can change the status to task scheduled for retry. (using the latest version 16.9)
You are correct. That’s hidden. I was expecting to select the failed task and use “retry” in the pull-down in the upper right corner (there is only delete there).
