Hello,
I’m looking for a way to manage mailing lists without using the “tenant” feature. Is it possible to create a user who isn’t a general administrator but has access to the mailing lists?
Yes. You can create a custom Role that grants only the mailing-list-related permissions and assign it to a regular account, without giving that account full admin or tenant-admin access.
The relevant permissions are:
sysMailingListGet – view mailing listssysMailingListCreate – create mailing listssysMailingListUpdate – update mailing listssysMailingListDestroy – delete mailing listssysMailingListQuery – search/list mailing listsTo set this up: create a Role object (WebUI: Directory › Roles) with enabledPermissions set to those five permissions, then assign that role to the target account via the account’s roles field (using a Custom role set referencing the role’s id, rather than the built-in user/admin/tenant-admin roles). This account will then be able to manage mailing lists via the WebUI or JMAP API without being a general administrator or needing the tenant feature.
Reference: Permissions and Roles.
Okay, that works so far,
but I can’t create new mailing lists—is there no way to specify the domain? What permissions are still required for that?
Edit: got it, I added 3 permissions with “domain”, it works now.
Is it possible to restrict the domain access to one specific domain for that account?
Could Someone please answer to this question? it would still be needed…
