Redirect without keep in user Sieve script creates implicit local copy (RFC 5228 violation)
A user Sieve script using redirect without keep (as per RFC 5228) still delivers a local copy to the Inbox. According to the RFC, redirect alone should suppress the implicit keep, meaning no local copy should be stored.
redirect "[email protected]";
Mail is forwarded externally, no local copy in Inbox.
RFC 5228, Section 4.1:
If the redirect action is used and no keep or fileinto actions are used,
the message is not implicitly kept.
Mail is forwarded successfully AND a copy appears in the local Inbox.
  1. Create user account on Stalwart
  2. Upload Sieve script via ManageSieve or Admin-UI containing only redirect “[email protected]”;
  3. Send a mail to that account
  4. Mail arrives at external address AND in local Inbox
Tested with both immediate delivery and after queue retry — both result in a local copy being kept.
delivery.delivered: to="[email protected]", code=250, details="Ok: 34009 bytes queued"
delivery.completed: elapsed=1000ms
Let me research how Stalwart handles Sieve redirect and implicit keep behavior.
The key finding is at lines 489-491:
// Fail-safe, no discard and no keep seen, assume that something went wrong and file anyway.
if !do_deliver && !do_discard {
    messages[0].file_into.push(INBOX_ID);
Now let me check how do_deliver is set to understand whether redirect sets it:
Fixed. The fix will be included in v0.16.9.
